Results 1 to 5 of 5
    New ROGer Array
    Nov 2020
    1
    Question Ryuo 240 CPU Frequency display stuck on 4.000GHz
    Hi all,
    I have the Ryuo 240 and when set to display the CPU frequency via Armoury Crate is always displays a constant 4.000GHz and never varies. The CPU is a Ryzen 5950X and motherboard is the Crosshair VIII Formula. The motherboard is running the latest BIOS release.
    Any ideas why the CPU frequency doesn't change depending on CPU load???*
    The BIOS shows the cores at 3.4GHz when idle and HWiNFO64 displays CPU core frequency variations depending on work load (slightly over 4.9GHz at times)
    Any help would be greatly appreciated.*
    New ROGer Array
    Nov 2018
    3
    Sameeeeeee!!!!
    Quote Originally Posted by antelopeslr5000 View Post
    Hi all,
    Yoo Bro i can feel you i got the ryujin 360, x570 gero wifi. 5600x still the same problem. only showing 4.000Ghz never go up or down.
    New ROGer Array DavyDee PC Specs
    DavyDee PC Specs
    MotherboardROG Crosshair VIII Impact
    Processor5950X
    Memory (part number)G-Skill
    Graphics Card #1ROG Strix RTX 2070S
    MonitorPredator Z35P
    CPU CoolerROG Ryujin 240
    CaseOphion M Evo
    Power SupplyThor 850
    Keyboard Corsair K70 MK2
    Mouse Corsair
    Headset Corsair
    Mouse Pad Corsair
    OS Win 10 x64
    Accessory #1 Misc ;o)
    Sep 2020
    12
    Same problem here - 5950X on a Crosshair VIII Impact. 4GHz it is, nothing else.
    Is Asus staff known to be coming here at all? Guess not.
    PS: I notice this problem exists with both Crate (not using, seeing your posts) and LiveDash (using).
    Can it be a problem of whatever readings of the BIOS not showing correctly? But then unlikely if HWinfo does read it correctly.
    Maybe the "layer" that feeds both LiveDash and Crate, some kind of API bug in the middle... just guessing.
    PPS: maybe a bug for Ryzen 5k's specifically. I had my Ryujin running with a 3900X before, and as far as I recall it showed correctly the dynamic boost frequency also.
    ROG Junior Member Array
    May 2016
    1
    same
    Same issue with rog ryugin 360 and 5900x. Cpu frequency stucks at 4000mhz and do nothing. What is going on?
    ROG Guru: Brown Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardCrosshair VIII Dark Hero
    Processor5900X 4.6ghz All core 1.3V, 5ghz single DOC
    Memory (part number)Gskill NEO 3600 CAS 14 32GB (4x8)
    Graphics Card #1ROG Strix RTX 3080
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 980 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 980 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks 500A Mesh
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur Virtuoso
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    80
    1,002
    Have you tried resetting the cooler in armory crate and re-applying the hardware monitor settings you want?
