Results 1 to 6 of 6
    New ROGer Array
    Mar 2019
    2
    GT-AC5300 Reliability Issue
    Hi there,
    First time poster, and I'm afraid a bit of a networking novice. I purchased this router as I saw rave reviews on it. I don't use most of the advanced settings and hoped this would give me a reliable connection. The range is great, however I have scheduled a restart for every morning at 5 as the wireless drops and will not restart without a router reboot every day. Sometimes it's certain devices that can't connect, sometimes the whole wirless (all frequencies) does down. At this point, I can't even connect to the dashboard through the IP on a wireless device to restart it. I have to do it manually.
    I have read through the forum, and can narrow down some of the issues
    1) I don't believe its overheating. There is nothing around it and its in the open.
    2) The scheduled restarts SHOULD give it a new lease of life every morning. Apparently not.
    3) I have approx 15 clients on it at a time... from what I have read, this should be fine.
    Can anyone help? Considering booking a course to learn more
    Thanks in advance.
    Dean
    New ROGer Array
    Mar 2019
    2
    Bump...
    Any help on this? Would be much appreciated.
    New ROGer Array
    Feb 2020
    12
    I wonder if maybe you just got a bad one & might want to RMA it. I have 30 devices (& 2 AC68 as nodes). Rebooting is good to just start fresh & I do so maybe twice a month but that isn't something that you should need to do daily.
    Also, as with anything electronic, make sure your firmware to up to date. I would reset it also just to make sure everything is stock and run the setup wizard again.
    But my guess is you just got a bad one. They'll do advance shipment so you will not be without a router.
    Good luck getting a quick resolution. I can assure you it's a great router when working right.
    New ROGer Array Jesseinsf PC Specs
    Jesseinsf PC Specs
    Laptop (Model)N/A
    MotherboardASUS ROG Maximus XI Extreme (Z390)
    ProcessorIntel Core i9 9900K
    Memory (part number)Corsair CMW128GX4M4E3200C16 - 128GB (4x32)
    Graphics Card #1NVIDIA - GeForce RTX 2080 Ti FE
    Sound CardCreative Labs Sound Blaster AE-9
    MonitorMSI Creator PS321URV (32 in 4k HDR600)
    Storage #1Samsung 980 Pro M.2 PCIe SSD 1TB
    Storage #2Samsung 970 Pro M.2 PCIe SSD 1TB
    CPU CoolerLian Li Galahad 360 (3x Uni fan SL120)
    CaseLian Li PC-011 Dynamic XL (ROG Certified)
    Power SupplyCooler Master V1200 Platinum
    Keyboard RAZER HUNTSMAN ELITE - LINEAR OPTICAL SWITCH (Red) w/ PBT Keycaps
    Mouse Razer Basilisk Ultimate with Charging Dock
    Headset Bowers and Wilkins P9 Signature
    Mouse Pad Razer Vespula V2 Mousepad
    Headset/Speakers Vanatoo Transparent One Encore w/ Rel HT/1003 Subwoofer
    OS Windows 10 Pro for Workstations
    Network RouterROG Rapture GT-AC5300
    Accessory #1 Microsoft Xbox Elite Wireless Controller Series 2
    Accessory #2 2x Logitech BRIO ULTRA HD PRO WEBCAM
    Accessory #3 7 Uni Fan SL120 fans for PC case
    Jesseinsf's Avatar
    Mar 2019
    34
    308
    I use to have the issue. here is what I didFor NON-Mesh networks)
    NOTE: if you use something then don't turn it off.
    • Updated the router to the latest firmware and then reset the router through the router reset pin hole on the router
    • Turn off any features you don't use. For me I turned off the following:
      • Turn off AI protect
      • Turn off All USB features
      • QoS settings set to Adaptive and choose manual settings and type in 1024 in the up and down link. Or 2048 if you have gigabit internet
      • Turn on Game accelerator and add all important devices
      • In "Open NAT, you can choose to enable port forwarding and add your games
      • Turn off VPN if you don't use this feature.
    • Under Wireless here is what I did: (For non Mesh network)
      • Do not use Smart Connect. Turn it off
      • Makes sure all SSIDs are all different
      • Under 2.4Ghz General menu, set it to "N" only and use 40 Mhz for channel bandwidth. Everything else stays at default.
      • Under 5Ghz 1 General menu, Disable Smart Connect and use 80Mhz for channel bandwidth and leave everything else at default
      • Under 5Ghz 2 General menu, Same as 5Ghz 1 but change the control channel to something like 161
      • Turn off WPS
      • In advanced menu turn off Airtime Fairness and Roaming assistant for all bands
      • Don't use a guest network if you don't have to
      • DHCP server in LAN setting. Manual assign all devices to the DHCP list
      • Under WAN, add a public DNS of your choice. I use Googles public DNS.
      • Turn off all AICloud 2.0 services if you don't use them
      • Turn off IPv6
      • In administration set the time change settings if you live in a time change area.
    ROG Junior Member Array
    Jan 2013
    3
    I have had nothing but crashes this past month since the updates. I'm done playing with this router and am probably moving on to something else and not ASUS
    Jesseinsf PC Specs
    Laptop (Model)N/A
    Jesseinsf's Avatar
    Mar 2019
    34
    308
    Quote Originally Posted by twitch77 View Post
    It doesn't matter what router brand you use. The more features you use in the router the more issues will occur. The GT-AC5300 series routers have a ton of features that are on by default. This is why I turn off features that I don't use and that don't benefit my home.
