Results 1 to 3 of 3
    New ROGer Array
    Jan 2021
    1
    PG27UQ No Sound... Please Help
    Hi...
    I'm sorry if I'm typing a story here, but I'm trying to share the suffering I went through >_< !
    I hope that I can find help here as I spent 2 weeks with Google trying to figure out the problem which is that my PG27UQ doesn't have sound while the other screen does. I tried reinstalling the driver (result is a device not migrated), tried to download aura (doesn't open and I think many have this error), tried cclean and reinstalled everything connecting with the sound jack + dp and dp alone but it is still the same.
    Those are the driver and software that I kept downloading:
    https://www.asus.com/us/Monitors/ROG...Desk_Download/
    • Windows 10 Pro
    • Intel 10900KF i9 10th Gen Processor 3.7GHZ 20MB cache processor
    • Gigabyte Aoros RTX 3090 24GB master graphics
    • Gigabyte Aoros Z490 Aoros ULTRA 10th gaming motherboard
    • MSI MAG CORELIQUID 360R Cooler
    • Thermal view 71 black tempered glass
    • Corsair HX1000i High-Performance ATTX Power Supply 1000 Watt 80 Plus
    • Corsair 3600 MHZ 2*32gb Vaengeance rgb pro gaming ram
    • WD 1TB NVME M.2
    Connected to two monitors
    • Asus PG27UQ connected through DP (the problematic monitor where the sound doesn't work) with dp only and the sound jack+dp
    • Asus MG28UQ (connected through DP (sound is perfectly fine)
    Thanks in advance
    ROG Junior Member Array
    Apr 2015
    1
    same problem
    i am having the same problem, have you got a fix??
    ROG Guru: Green Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD NVMe Samsung 970 EVO Plus 500GB
    Storage #2SSD NVMe Samsung 960 EVO 250GB | SSD NVMe Corsair Force MP510 240GB | SSHD AHCI Seagate FireCuda 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Headset/Speakers Logitech Z333
    OS Windows 11 Pro 64 bit 21H2/CO/22000
    MoKiChU's Avatar
    Aug 2013
    404
    661
    Quote Originally Posted by ciderbob View Post
    There will be no fix, because there is no issue, the PG27UQ monitor don't have built-in speakers.
    It has a 3.5mm jack for headphones or external speakers because it serves only as a passtrough of audio codec from your GPU via HDMI/DP, so even if it means using headphone or external speakers, it is better to use the audio codec from your motherboard via 3.5mm jack which will be more efficient.
Tags for this Thread
