AI Suite 3 - Repack
levelKro
Hello, today is for report my AI Suite 3 package of all and up-to-date applications of this suite.
Since I known the AI Suite, I have many times problems to find modules and work it correctly, some module can cause error if another is present, or ASUS not update a mainboard model with latest app version, etc....
This GitHub is created for download with one pack all the AI Suite and use it without any errors or compatibility issues. No modification of files, is same of the ASUS website, no additions of unofficial application, and without any malware.
If you have a module not listed in this package, please report the link to download for adding it.
87597
https://github.com/levelKro/AI-Suite-III-Repack
15 REPLIES 15
zocker
This Repack is nice, but the latest Version is v3.00.69. 🙂
Can i replace it in this Repack?!
i7-13700K
TUF GAMING Z690-PLUS
ASUS TUF Gaming GeForce RTX 4090 24GB
Creative Sound BlasterX AE-5 Plus
32GB Corsair Vengeance CMK32GX5M2B5600C36
Samsung SSD 970 EVO Plus 1TB (System)
Samsung SSD 970 EVO Plus 2TB (Gaming)
Sure, can add missing versions, just post me the link of download (Mainboard support page).
https://rog.asus.com/motherboards/rog-strix/rog-strix-z390-f-gaming-model/
Hey! I have this motherboard! Can I download the version you have uploaded?
And should I download folder by folder. v3.00.65
Every gamer has suffered from small-screen videos
Just download https://github.com/levelKro/AI-Suite-III-Repack/archive/master.zip , extract files and execute the AsusSetup.exe (or Setup.exe, same goal).
Thanks! For info. I download it.
And well done.
Thanks! levelKro
Correction, the latest version is 3.00.76
https://dlcdnets.asus.com/pub/ASUS/mb/LGA1200/ROG_MAXIMUS_XIII_HERO/ASUS_AI_Suite_3_V3.00.76_Install...
Thank you, I look files and updates files if needed in few minutes.
Thank for the update. I have also modified the package because I have found another mistake with AI Suite.
3 modules cannot be installed at the same time and this is because this is 3 versions of the same module, but with different name, and features.
  • FanXpert 2 is the most lite, only control Fans,
  • Performance and Power Saving Utilities have the FanXpert 2, but also the PC Cleaner, TPU, EPU and DIGI+ VRM features,
  • Dual Intelligent Processor 5 is the same of Performance and Power Saving Utilities, with the Turbo App and Dashboard.
This is the reason of this Repack 🙂
zocker
Thanks for the new Version!
i7-13700K
