Strix 1080 Ti - Fan Connect II max ampere?
INDIVIDUUM
Hey Guys,
dont know if anyone here can answer me this or help me with that but i thought id try.
I have a ROG Strix 1080 TI and a AIO mounted to it.
The Software for the AIO wont let me control the fans inside the provided software.
I know that the Strix has 2 headers for case fans, however i never used this function but it would come in handy to connect the radiator fans and control them via the GPU temperature instead of the Temp of the liquid.
But i couldnt find how much amp. you can put on the headers without frying the card. Will RGB Fans work on those headers? Should i avoid plugging in any Fan splitter into the GPU headers?
Anyone has experience with this or knows details from ASUS themselves?
Thanks for taking the time to read 🙂
Silent_Scone
Super Moderator
The headers are standard PWM, so 12W.
