Fans Configuration Help!
simonlambert
Hi all, I have a Strix Z490 Gaming-E Mobo, a Lian Li 011 Dynamic XL ROG and an arctic liquid freezer ii 360. In total I have 7 Phanteks fans and 3 for the AIO. I tried different configuration to have the AIO fans controlled by the motherboard separately from the pump, but I cannot find a way to do it. Right now, the AIO is connected to the AIO_PUMP with the 3 fans. I tried to connect the 3 AIO fans to the CPU_FAN, but they only run at 300RPM constant. The ASUS AI 3 software is showing me the speed, but there is an exclamation point in the graphic section, and there is nothing I can do to control them. I also tried to connect the fan to CHA_FAN2 hoping to control them with the CPU temp setting, but still no go. Anybody out there with that kind of knowledge to help me?
Thanks!
Enderwiggin03
Try using the bios for setting fan speeds.
