Results 1 to 5 of 5
01-28-2021 11:31 PM #1
- Join Date
- Jul 2011
- Reputation
- 10
- Posts
- 22
Adaptive or stay Manual mode opinions for my MXI Formula 9700k overclock
I've been using Manual Mode for the past year or so and have been reading online about adaptive mode and trying to determine if it's necessary considering my current voltages/OC. I first utilized the Auto overclock feature to see how far I could go. It resulted in 5.2Ghz at something like 1.34v or around there, which I thought was pretty good. I then found der8auer's 9900k overclocking guide (I have a 9700k) which I've been using this setup for the past year or so. Since recently reading some stuff online I was considering dialing in adaptive mode, but thought maybe I'd throw it on the forums to see if any users/Asus folks see any reasons to or not to change based on my current specs.
My build:
Asus Maximus XI Formula
9700k OC 5.0Ghz @ 1.230v
32G GSkill 3000 RAM
EVGA 2080 Ti XC
Corsair AX1600i PSU
Corsair 1000D
Dual loop 480 Radiators
I use HWInfo64 to monitor temps and voltages and for the most part I'm sitting at 1.17v idle and 1.23v (roughly) at load. Temperatures range from low 50's to low 60s playing Division 2, Valhalla, WD Legions, Hitman 3, Warzone and so on.
My understanding of Adaptive allows for voltages to relax when idle and or mild use and adjust when needed, Manual just sets it at a hard voltage and from my situation adjust slightly when idle and moderate use as stated above min 1.17 up to 1.23 at load maybe peaking to 1.25 on some games if I recall, still good voltages from what I've read.
Any reasons to adjust to Adaptive for daily/long term usage?
Here's a shot of my build -
02-07-2021 08:22 PM #2
- Join Date
- Jul 2020
- Reputation
- 10
- Posts
- 9
nice build,
adaptive is similar to auto
i use adaptive, just select adaptive mode
then in the field that says total turbo adaptive voltage, type in your stable voltage 1.345 @ 5.2
Using this you can mimic TVB by setting - 54/54/52/52/52/52/52/52 probably - and avx will run at 52. Since avx runs a higher voltage, might as well run non avx at equal, right?
it probably just uses less power to be honest and could be less stable than manual voltage but its fun to try it.
Using the ai calculated fields on the right you can set a voltage for the 2cores, adjust the ai optimism to max and type in cooler score 250/max
Another useful time to use adaptive is for tuning stable AVX-1/2 loads and temps. as they require more voltage
use HW info and CPUZ simultaneously to confirm your voltage, sometimes they can be wrong, aida 64 is fairly accurate but i havnt used it that long
the performance gains are minimal though unless you are benchmarking, i'd stick with a avx stable voltageLast edited by Steveo_; 02-07-2021 at 08:40 PM.
02-07-2021 08:56 PM #3
- Join Date
- Jul 2011
- Reputation
- 10
- Posts
- 22
Thanks
I feel like my chip runs great with the voltages I have considering some of the volts/temps I've seen for similar clocks is well above what I'm able to achieve. I just wasn't sure if there were any improvements that could be gained from adaptive over my manual setup.
I might see about creating a profile using adaptive to see if there's anything noticeable between the two.
Thanks for the reply Steveo, much appreciated.
02-08-2021 08:19 AM #4
Adaptive has the benefit of using the stock VID table up until using the turbo multiplier.
However, the voltage cannot be set lower than the stock vid for a given ratio. Sometimes more voltage can be needed to accommodate for load transitioning if previously using a manual or fixed voltage. It's worth it for the benefit of power saving, if you care about such things.
02-09-2021 01:58 AM #5
- Join Date
- Jul 2011
- Reputation
- 10
- Posts
- 22
I do recall reading something regarding the stock vid being the lowest voltage one can achieve for said clock. With current settings I range from 1.17v - 1.235v idle/load with temps between 28C-65C based on HWiNFO64. I'll have to do some testing to see if there's any benefits overall, seems where I'm at is a lot lower than what I've seen suggested online, 5.0Ghz @ 1.32v-1.34v or somewhere around there, so I might be at a good spot with a really good chip.
Thanks for the reply Silent Scone.
