Results 1 to 5 of 5
    New ROGer Array
    Jan 2021
    2
    Question ROG Delta S sounds way worse than my non-S
    For some reason the sound on the Delta S sounds really 'hollow' or tinny. I've tried disabling all enhancements in windows (weren't any active) and I've disabled all other audio devices. It is on the latest firmware. The sound from the microphone is also very muffled, way different than the on the non-S. I've tried putting the non-S's microphone in the Delta S but the sound is still muffled.
    I've updated the firmware on it to the latest version, tried it in a laptop and a different computer and ps4, sound is hollow everywhere.
    Can anyone help me or tell me whats going on? Anyone else with this problem?
    ROG Enthusiast Array skyhopper01 PC Specs
    MotherboardMaximus XIII Extreme
    ProcessorIntel I9-11900k @ 5.2ghz
    Memory (part number)GSKILL Trident Z RGB 32GB @ 4133mhz
    Graphics Card #1Asus ROG Strix 3090 OC
    MonitorAsus ROG Swift PG32UQX 4k 144HZ
    Storage #1Samsung 980 EVO 500GB
    Storage #2Samsung 860 EVO SSD 1TB
    CPU CoolerASUS ROG Ryujin 360mm
    CaseROG Strix Helios
    Power SupplyAsus ROG Thor 1200p
    Keyboard Asus ROG Claymore II
    Mouse Asus ROG Gladius III Wireless
    Headset ASUS ROG Delta
    Mar 2018
    11
    45
    After owning and comparing both headsets side by side, I actually ended up keeping the Delta S. As you have noticed, there is a different sound stage on the S compared to the regular. The S has the bass dialed back and has a more flat and open sound stage. The highs and mids are more pronounced and clear. Make sure you update the devices firmware in armory crate and I also recommend using the FPS preset. I dial back the reverb to 20 percent and increase the bass boost to 50 percent. The S Sounds absolutely amazing IMO.
    New ROGer Array
    Jan 2021
    2
    Quote Originally Posted by skyhopper01 View Post
    First of all thank you for replying I guess taste in soundstage etc is subjective. I played around a lot with the settings and presets but I couldn't find anything I liked. How do you feel about the microphone though? The AI sound suppresion seems to be forced on at all times, even when disabling it.
    Mar 2018
    11
    45
    No problem, I have heard about some users having issues with the mic but honestly I have not used it or tested it yet. I mostly place single player games.
    Moderator Array ROG Guy PC Specs
    ROG Guy PC Specs
    Laptop (Model)ROG Zephyrus G14
    MotherboardROG Crosshair VIII Impact
    ProcessorAMD Ryzen 9 3900X
    Memory (part number)F4-3600C16D-32GTZN
    Graphics Card #1ASUS TUF Gaming RTX 3080 10G
    MonitorROG Strix XG32VQR
    CaseLian Li TU150
    Power SupplyCorsair SF750
    Keyboard ROG Falchion
    Mouse ROG Keris
    Headset ROG Delta
    Mouse Pad ROG Scabbard II
    Headset/Speakers Audioengine A5+
    OS Windows 10 Pro
    Network RouterASUS RT-AX86U
    May 2016
    2
    Up for this thread. Do you have any recommedations for sound settings using the Delta S?
Tags for this Thread
