Which M.2 ssd
haydenwse
I have a Z170-P D3 which currently has a 256GB 2.5" ssd and want to upgrade to a 2TB m.2 2280. I know that it has Pcie 3.0 and the book says I have 1 x M.2 Socket 3 with M Key for both sata and pcie mode.
Most of the drives I see listed are pcie 3.0 X 4. Is that what I am looking for? Any suggestions or help would be most appreciated.
4 REPLIES 4
toronto699
Hope This Is helpful , M Key Is The Notch On The Motherboard
https://rog.asus.com/articles/guides/buying-an-m-2-ssd-how-to-tell-which-is-which/
toronto699
Hope This Is Useful , M Key Is The Notch On The Motherboard and The SSD Card , 2280 is length of Card , pcie 3.0 X 4. Should work , There Should Be A Screw On Motherboard to Install The SSD ,
this will give you idea what to look for upgrade my Motherboard
https://www.crucial.com/compatible-upgrade-for/asus/z170-p-d3
https://www.youtube.com/watch?v=NCIqZjo34rw
Samsung Is The Best And Most Expensive
Thanks for the reply. My motherboard has ddr3 and most of the m.2 cards i am looking at say that they have "Built-in 2GB DDR4 DRAM and SLC caching accelerate burst performance and prevent slowdown during intensive workloads." Is this compatible? below is the link to one i am considering. Trying not to buy any more components that do not work with my system.
https://www.newegg.com/mushkin-enhanced-pilot-e-2tb/p/N82E16820226902?Item=N82E16820226902&bc_pid=Tj...
toronto699
Yes Should Work
No Software Comes With That SSD ,
