Strix G712LV AuraSync SMART Mode not working
BishakhFlynn
Hello everyone!
Has anyone experienced problems with the Armoury Crate Aura effects?
There is a SMART Mode that changes LED lights from Green --> Yellow --> Red depending on either CPU temp / CPU usage.
I am not sure if it was a BIOS update that caused this, but sometime in January the CPU temperature stopped displaying itself on the Armoury Crate tile. And therefore the SMART Mode change of LED lights from Green --> Yellow --> Red on the basis of CPU temperature stopped working [However, it is to be noted that the change of color based on CPU usage was still working].
I tried looking for updates, and then reinstalled Armoury Crate/Aura Creator. This solved a part of the problem, and the CPU temperature was back on display on the Armoury Crate tile. However, the LED lights still don't change from Green --> Yellow --> Red based on the temperature.
Any ideas?
LeoLim
My ROG Strix G (G531GT) also has exactly similar problem, maybe it is a update fault?
i have same issue since january 2021... all modes work properly only smart temperature wont work , it just stuck on solid green , itry everithing even fresh instal of win etc but nothimg was work for me and I have Zephyrus S 17 GX701GXR.
I realy hope they fix this . This mode i use in gaming daily...
if anyone know how to fix it please help us please please
