Results 1 to 7 of 7
    ROG Enthusiast Array Swiso PC Specs
    Swiso PC Specs
    MotherboardASUS Rampage Extreme V 3.1
    Processori7 5930K
    Memory (part number)CMD32GX4M4B3000C15
    Graphics Card #1EVGA GTX 980Ti Classified
    Graphics Card #2EVGA GTX 980Ti Classified
    MonitorNEC 30" LCD3090 Wqxi
    Storage #1Samsung 850 Pro 1TB
    Storage #2Samsung 850 Pro 256GB
    CPU CoolerNoctua NH-D15S
    CaseLian-Li PC-V2120X
    Power SupplyCorsair AX1500i
    Keyboard Das Keyboard
    Mouse Steelseries Sensei
    Headset Beyerdnamic MMX 300
    Headset/Speakers CREATIVE GigaWorks T40 Series II
    OS Win 10 Pro - Linux Mint 17.3
    Accessory #1 Samsung 950 Pro 512GB
    Accessory #2 ASUS BW-16D1HT
    Accessory #3 WD Caviar Black 2TB
    Apr 2016
    11
    34
    Question Updating drivers for chipset of Zenith II Extreme Alpha
    Waiting for some parts still to arrive for my new PC, I was looking for the most recent drivers for the MB.
    What you guys tipically do, when you update those drivers ? Check support page of your MB or you check directly at AMD ?
    It look like some drivers on AMD are more recent....
    Swiso PC Specs
    Processori7 5930K
    Apr 2016
    11
    34
    Thanks uli1234,
    I saw that page....my question is: usually you'll wait till the new stuff appear on the ASUS support page of your MB or go directly to AMD page ?
    The Chipset driver size on the ASUS support page is 436.52MB (AMD Chipset Driver V5.12.0.38(V19.20.28) for Windows 10 64-bit.(WHQL), meanwhile the version on AMD site is version 2.13.27.501and size 51 MB....
    Why such a difference ?
    And why no sequence on the designation number ?
    Assuming a first and clean install of you MB, which drivers you would go with ?
    thanks
    ROG Guru: Green Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD Samsung 970 EVO Plus 500GB
    Storage #2SSD Samsung 960 EVO 250GB | SSD Corsair MP510 240GB | SSHD Seagate 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Mouse Pad PECHAM MPad-XXL
    Headset/Speakers Logitech Z333
    OS Windows 10 64 bit
    MoKiChU's Avatar
    Aug 2013
    303
    555
    Quote Originally Posted by Swiso View Post
    Thanks uli1234,
    thanks
    From the support page of your motherboard : Chipset + iGPU Drivers Package
    From AMD support page or from my thread : Chipset Drivers Package
    I therefore advise you to install the version which comes from AMD or from my thread.
    Swiso PC Specs
    Processori7 5930K
    Apr 2016
    11
    34
    Quote Originally Posted by MoKiChU View Post
    Thank you !
    By iGPU you mean the GPU drivers right ?
    MoKiChU PC Specs
    CaseBitFenix Enso
    Mouse Logitech G502
    MoKiChU's Avatar
    Aug 2013
    303
    555
    Thank you !
    You're welcome,
    No, there is no mistake, I meant iGPU, GPUs having dedicated drivers packages.
    - Chipset Drivers Package : For AMD CPU on AMD Chipset (can be used for AMD APU (CPU+iGPU) but GPU Drivers Package is necessary in addition)
    - Chipset + iGPU Drivers Package : For AMD APU (CPU+iGPU) on AMD Chipset (can be used for AMD CPU but iGPU Drivers will not be used)
    - GPU Drivers Package : For AMD GPU (can be used for AMD iGPU if Chipset Drivers Package (without iGPU Drivers) is installed)
    Now if your question is rather, why ASUS put a Chipset + iGPU Drivers Package in your motherboard support page when there is no Threadripper APU ? Probably a mistake on their part, you have to ask them.
  7. #7
    Swiso PC Specs
    Processori7 5930K
    Apr 2016
    11
    34
    Ah..I see it now...
    Thank you very much.
    All clear now.
