Results 1 to 2 of 2
    New ROGer Array
    Sep 2019
    1
    Question Rog Strix z490-H ram problem
    hello,
    I have two Ram sticks, Corsair VENGEANCE® RGB PRO 16GB (2 x 8GB) DDR4 DRAM 3200MHz
    when I put both in the warning light flashes error for Dram and also the Cpu error light
    but 1 stick works fine inside.
    this is a partial new build I got the motherboard and a new PSU as well, and when I first started the PC both ram sticks worked.
    and the next day the other Ram failed
    I should also point out one of the ram sticks when in alone doesn't work at all
    I just want to be sure its the Ram before I replace
    ROG Guru: Orange Belt Array Saltgrass PC Specs
    Saltgrass PC Specs
    MotherboardMaximus XIII Hero
    Processori9 11900K
    Graphics Card #1EVGA RTX 3090 FTW
    Sound CardOn Board
    MonitorDell AW3420DW
    Storage #1Samsung 980 Pro 2 TB
    Storage #2Samsung 860 Pro 1 TB
    CPU CoolerCooler Master Hyper 212X
    CaseCooler Master
    Power SupplyAntec HCP Platinum 1000
    Keyboard ASUS Strix Flare
    Mouse ASUS Chakram
    Headset/Speakers Logitech wired 5.1
    OS Win 10 Pro
    Network RouterROG Rapture GT-AX11000/AXE11000
    Accessory #1 VR Headset
    Accessory #2 Saitek X52
    Jan 2014
    18
    444
    It does appear the ram is bad on that one stick.. In case you don't know, ram is very sensitive to static electricity..
Tags for this Thread
