Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    ROG Member Array
    Nov 2020
    22
    15
    Exclamation RefreshRateService not working
    Hello ASUS, do you know your program RefreshRateService doesn't work?
    actual for versions 2.0.1 2.0.3 2.0.5 2.0.6
    New ROGer Array
    Nov 2019
    1
    probably broken uninstaller, uninstall normally then open cmd as admin and type sc delete RefreshRateService
    Then try the version 2.0.6
    ROG Member Array
    Nov 2020
    22
    15
    Quote Originally Posted by blacker96 View Post
    Not working too
    Miniatura de Adjuntos Miniatura de Adjuntos Screenshot 2021-02-25 145315.jpg
    ROG Member Array
    May 2015
    24
    is there any fix yet
    ROG Member Array
    Jul 2014
    23
    The same problema any solution?
    ROG Member Array
    Nov 2020
    22
    15
    Quote Originally Posted by Tri4C3 View Post
    No, ASUS doesn't care about our problem.
  7. #7
    ROG Enthusiast Array sa.783 PC Specs
    sa.783 PC Specs
    Laptop (Model)Zephyrus S17 GX701GVR
    MotherboardAsus ROG Zephyrus S17 GX701GVR
    ProcessorIntel Core i7-9750H
    Memory (part number)32GB DDR 4
    Graphics Card #1RTX 2060 6GB
    Storage #1SAMSUNG_970 PRO
    Mouse ROG Pugio II
    OS Windows 10 Home 64-bit
    Aug 2018
    28
    36
    Version 2.0.8 works
  8. #8
    ROG Member Array
    Nov 2020
    22
    15
    Quote Originally Posted by sa.783 View Post
    Version 2.0.8 works
    Its a Miracle, in version 2.0.8 the problem has been really fixed.
    It took only 1.5 years to fix this it.
    V2.0.8
    Modify to write Get display info to the file, cancel the pipe method:
    1) Fix TK:271254,G732LWS,Overdriver Panel issue
    2) Fix TKM 265348 GX701GVR Armoury refreshrate無法啟用
    V2.0.7
    1. Fix sometimes panel overdriver cannot be switched in AC mode (TT 20039281).
    Related Topic:
    https://rog.asus.com/forum/showthrea...verse-ghosting
    Archivos Adjuntos
  9. #9
    ROG Member Array
    Jul 2019
    8
    Hello I'm with 2.0.8 asus rog G712LW and 3ms response button in armory still missing reinstalling everything but still not come and 3ms didn't working, cmoon asus fix your trash program
  10. #10
    sa.783 PC Specs
    Mouse ROG Pugio II
    Aug 2018
    28
    36
    Quote Originally Posted by ivoccaa View Post
    Hello. After the last update, the 3ms button disappeared for me too. version 2.0.8
Tags for this Thread
