Sound skipping issue
san2222
I have a newly built system based on the A520M motherboard and there seems to be issues with audio. While playing media (YouTube, certain games), there are instances where chunks of audio are skipped. I tried drivers from both Microsoft (10.0.19041.264 ) and latest Realtek drivers. The issue is especially pronounced with Realtek (6.0.8955.1). Looks more as a software/driver issue than hardware. I tried posting this in AMD forums but was suggested to post here instead.
My specs:
CPU: 3500X
RAM 16 GB
Thanks
san2222
After quiet some time hunting down the issue. I think I solved it. Looks like there are some sort of driver conflicts.
Two driver files audioendpoint.inf and c_swdevice.inf have the same versions (10.0.19041.1) but DIFFERENT driver dates. The first one has 12/06/2019 while the second one has 06/21/2006. Is this even possible?
87928
After uninstalling and scanning for hardware change in Device Manager, I got a warning in Event Log:
Device SWD\MMDEVAPI\{0.0.0.00000000}.{ba8a4a41-2189-412a-81a6-d027431da88e} was not migrated due to partial or ambiguous match.
Last Device Instance Id: SWD\MMDEVAPI\{0.0.0.00000000}.{02e8c993-5c78-44f7-ae00-bf167db655a8}
Class Guid: {c166523c-fe0c-4a94-a586-f1a80cfbbf3e}
Location Path:
Migration Rank: 0xF00000000000F120
Present: false
Status: 0xC0000719
After which the following log:
Device SWD\MMDEVAPI\{0.0.0.00000000}.{ba8a4a41-2189-412a-81a6-d027431da88e} was configured.
Driver Name: audioendpoint.inf
Driver Date: 12/06/2019
Driver Version: 10.0.19041.1
Driver Provider: Microsoft
Driver Section: NO_DRV
Driver Rank: 0xFF0000
Matching Device Id: MMDEVAPI\AudioEndpoints
Outranked Drivers: c_swdevice.inf:SWD\GenericRaw:00FF3001
Device Updated: false
Parent Device: HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_104386C7&REV_1003\5&319e220&1&0001
Hence as of now audioendpoint.inf is loaded and the sound issue is fixed.
The only bummer is that the below listed items have no drivers loaded. Device Manager says "No driver files are required or have been loaded for this device". Weird!
87929
MoKiChU
Level 40
All the devices listed in "Audio inputs and outputs" are system devices, using system drivers which are not meant to be updated (whose version corresponds to the version of the system, Windows 10 2004/VB/19041.x in your case).
You have an ASUS PRIME Realtek motherboard, so :
You need Realtek Audio Drivers (UAD - ASUS ROG/TUF/PRIME RTK MB) from the first post of this thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
If your DPC latency issue persists, in order to try to fix it, follow this process (also visible in TIPS at the bottom of all my audio drivers threads) :
1) Disable hibernation :
- Right-click Windows Start button then click Search.
- Search for cmd. In the search results list, right-click Command Prompt and then click Run as administrator.
- If/When you are prompted by User Account Control, click Continue.
- At the command prompt, type powercfg.exe /hibernate off and then press Enter then close the Command Prompt
2) Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with MSI Mode Utility (Right click on "MSI_util_v3.exe" > Run as administrator), then Apply, then close MSI Mode Utility & restart your PC
I did as you said. The drivers have been updated and now there is one extra entry in Device Manager, which was not there before: Microphone. I don't use a microphone so I went to Realtek Audio Control and switched off "Disable front panel jack detection" and then it was gone. The strange thing is I don't use a front jack and there is nothing plugged in.
As said before there is no sound issue as of now. Will need further testing. However, in Device Manager Windows says drivers are not required for "Speakers (Realtek (R) Audio)". I could just ignore this.
