Page 3 of 8 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 72
  1. #21
    ROG Guru: Orange Belt Array Saltgrass PC Specs
    Saltgrass PC Specs
    MotherboardMaximus XIII Hero
    Processori9 11900K
    Graphics Card #1EVGA RTX 3090 FTW
    Sound CardOn Board
    MonitorDell AW3420DW
    Storage #1Samsung 980 Pro 2 TB
    Storage #2Samsung 860 Pro 1 TB
    CPU CoolerCooler Master Hyper 212X
    CaseCooler Master
    Power SupplyAntec HCP Platinum 1000
    Keyboard ASUS Strix Flare
    Mouse ASUS Chakram
    Headset/Speakers Logitech wired 5.1
    OS Win 10 Pro
    Network RouterROG Rapture GT-AX11000/AXE11000
    Accessory #1 VR Headset
    Accessory #2 Saitek X52
    Jan 2014
    18
    383
    OK, I hope it helps but just in case it doesn't check this..
    eth7: Auth 0C:7A:XX:XX:90:8E, status: Successful (0), rssi:0
  2. #22
    ROG Guru: White Belt Array
    Nov 2018
    31
    118
    Quote Originally Posted by Saltgrass View Post
    i dont have that mac address posted? where you got it from? that entry?
  3. #23
    Saltgrass PC Specs
    Processori9 11900K
    Sound CardOn Board
    CaseCooler Master
    Mouse ASUS Chakram
    OS Win 10 Pro
    Jan 2014
    18
    383
    You won't have that MAC address. You will use the one you show in your system log for eth7 and compare it to the clients listing on the Router..
  4. #24
    Nov 2018
    31
    118
    got confused thier, yup already did that and eth7 is 5ghz_1
  5. #25
    Saltgrass PC Specs
    Processori9 11900K
    Sound CardOn Board
    CaseCooler Master
    Mouse ASUS Chakram
    OS Win 10 Pro
    Jan 2014
    18
    383
    Ok, I give up..
  6. #26
    Nov 2018
    31
    118
    Ok, I give up..
    i dont get what your trying to ask me to do
    i already did check the eth7 is the 5Ghz_1 and the macs address the connecting to it are my phones and other gadgets the the routers always gives this no part of aimesh cant update ip
    its doing that to the device thats connecting to it randomly
  7. #27
    Nov 2018
    31
    118
    like this one
    Mar 3 22:45:21 wlceventd: wlceventd_proc_event(527): eth7: Auth CE:C9:01:C1:B4:76, status: Successful (0), rssi:0
    thats my kids ipad connecting to the 5ghz_1 channel
    Mar 3 05:25:04 wlceventd: wlceventd_proc_event(527): eth7: Auth 90:2B2:86:A7:E1, status: Successful (0), rssi:0
    this one is my phone connecting to the same 5Ghz_1
  8. #28
    Nov 2018
    31
    118
    and now its the time its starting to go crazy again, its been like 14 days since my last factory default reset
    Mar 3 18:42:24 kernel: B2:6A:16:B5:B6:E1 not mesh client, can't update it's ip
    Mar 3 19:24:32 wlceventd: wlceventd_proc_event(508): eth6: Disassoc 34:79:160:91:2B, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
    Mar 3 19:24:32 wlceventd: wlceventd_proc_event(508): eth6: Disassoc 34:79:160:91:2B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
    Mar 3 19:24:34 wlceventd: wlceventd_proc_event(527): eth6: Auth 34:79:160:91:2B, status: Successful (0), rssi:0
    Mar 3 19:24:34 wlceventd: wlceventd_proc_event(556): eth6: Assoc 34:79:160:91:2B, status: Successful (0), rssi:0
    Mar 3 19:24:48 wlceventd: wlceventd_proc_event(508): eth6: Disassoc 34:79:160:91:2B, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
    Mar 3 19:24:48 wlceventd: wlceventd_proc_event(508): eth6: Disassoc 34:79:160:91:2B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
    Mar 3 19:24:52 wlceventd: wlceventd_proc_event(527): eth6: Auth 34:79:160:91:2B, status: Successful (0), rssi:0
    Mar 3 19:24:52 wlceventd: wlceventd_proc_event(556): eth6: Assoc 34:79:160:91:2B, status: Successful (0), rssi:0
    Mar 3 20:00:26 wlceventd: wlceventd_proc_event(508): eth8: Disassoc B2:6A:16:B5:B6:E1, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
    Mar 3 20:02:50 kernel: B2:6A:16:B5:B6:E1 not mesh client, can't update it's ip
    Mar 3 20:04:13 wlceventd: wlceventd_proc_event(556): eth8: Assoc B2:6A:16:B5:B6:E1, status: Successful (0), rssi:0
    Mar 3 20:04:17 kernel: B2:6A:16:B5:B6:E1 not mesh client, can't update it's ip
    Mar 3 20:29:00 wlceventd: wlceventd_proc_event(508): eth8: Disassoc B2:6A:16:B5:B6:E1, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
    Mar 3 20:29:00 wlceventd: wlceventd_proc_event(556): eth6: Assoc 32:E7:24:88:FB:6A, status: Successful (0), rssi:0
    Mar 3 20:29:08 kernel: B2:6A:16:B5:B6:E1 not mesh client, can't update it's ip
    Mar 3 20:29:12 wlceventd: wlceventd_proc_event(508): eth6: Disassoc 32:E7:24:88:FB:6A, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
    Mar 3 20:29:13 wlceventd: wlceventd_proc_event(527): eth7: Auth CE:C9:01:C1:B4:76, status: Successful (0), rssi:0
    Mar 3 20:29:13 wlceventd: wlceventd_proc_event(556): eth7: Assoc CE:C9:01:C1:B4:76, status: Successful (0), rssi:0
    this types of logs is not thier when you freshly reset factory defaults
    and now i can feel the problem again like i always get dns error, dns domain, err timeout so other err problem, need to keep refreshing the pages, im now wating till what day it would have zero internet to the pc and devices, then i'll check again the logs
  9. #29
    New ROGer Array
    Feb 2021
    1
    I am not sure but maybe try calling the support to open a support case for your issue.
    Other thing that could help is scheduling a reboot every few days before your Router gets to the point where you have to factory default it.
    I am not sure if you have tried scheduling reboots. I also understand that your Router shouldn't get to point where it doesn't work after 2 weeks hence the reason I suggested about opening a support case with Asus.
  10. #30
    Saltgrass PC Specs
    Processori9 11900K
    Sound CardOn Board
    CaseCooler Master
    Mouse ASUS Chakram
    OS Win 10 Pro
    Jan 2014
    18
    383
    It isn't important as to which Radio it is connecting, but the device that is connecting. If it shows as your iPad when these errors occur, take that device offline to see if it helps.
    If you take the current eth7 device offline, another device may change its designation and assume the eth7, but if it isn't having problems, then the errors will not return.
    There is another report you might check on a Wireless computer running Win 10. Maybe you could associate with what it shows with what the Router System Log shows. Make note of where the reports is stored so you can copy it to your desktop to check.
    In admin command prompt:
    netsh wlan show wlanreport
    I still have to believe, the factory resets are necessary because, over time, the system corruption is bad enough it inhibits the system functions. Is it being caused by the Router or your network, I don't know..yet..!
