Results 1 to 10 of 10
    ROG Enthusiast Array mattpunx90's Avatar
    Feb 2020
    31
    GL504GW just 1hr of Battery Life
    Does anyone found a way to improve this machine very poor battery life?
    Read somewhere Asus disabled iGPU so it runs on dGPU when disconnected and that cause the high battery drain. Is it actually that way?
    any help or information would be appreciated
    Moderator Array
    Feb 2019
    14
    774
    Hello matt,
    May you help to run the Battery Report? We might need to check if the battery capacity has any issue.
    Feb 2020
    31
    actually i did, and it says the battery is ok
    Moderator Array
    Feb 2019
    14
    774
    Hi Matt,
    then may you share the detail scenario?
    Like what mode did you set to and what program or game are you playing.
    Feb 2020
    31
    Quote Originally Posted by Blake@ROG View Post
    Hi Matt,
    It's on windows mode/balanced and just using browser to video playback. Nothing that should drain it as fast as it does.
    i checked and dGPU seems not to be using while battery use. Nontheless battery saving mode is ON, screen dimmed to lowest bright, and the laptop is providing me no more than 1 hour and 8 mins of battery life. How can this be running only on iGPU and web browsing?
    Feb 2020
    31
    Still waiting for a response on why this laptop supposed to have optimus and run on igpu while on battery use can't provide over 1 hour of use
  7. #7
    ROG Guru: Green Belt Array
    Feb 2019
    118
    556
    I have yet to see one of the "Gaming" laptops get decent battery run time. My G752VY under heavy use gets 45 mins tops and about 2 hours doing menial tasks with a brand new battery. They are power hogs.
  8. #8
    ROG Member Array
    Mar 2019
    7
    Repaste
  9. #9
    Feb 2020
    31
    Quote Originally Posted by xcosmos View Post
    Repaste
    if it was overheating, yes. Battery life, another topic
  10. #10
    Feb 2020
    31
    Quote Originally Posted by BigJohnny View Post
    it's supposed to be a laptop with a 3:30hs of battery life at least
