Results 1 to 2 of 2
    ROG Junior Member Array
    Apr 2015
    1
    Post G703GXR max hard drive sizes
    Hi All,
    I have a G703GXR and am looking to pimp the storage. Has anyone put an 8TB 2.5 ssd into one of these, I cant find info to tell if this size would be supported. If it isnt then I guess it will be a 4TB M2
    Thanks
    ROG Guru: Blue Belt Array
    Nov 2012
    75
    776
    The external size of the Samsung SATA III SSDs are the same, any model would fit fine,
    https://www.newegg.com/samsung-8tb-8...B&gclsrc=aw.ds
    As for the M.2 NVMe SSDs, you do know there are 8TB models out there too?
    https://www.newegg.com/corsair-8tb-m...quicklink=true
    You are more limited by your checkbook than anything else.
    Good Luck
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
