Results 1 to 4 of 4
    New ROGer Array
    Feb 2021
    3
    B550 Boost limited to 200 mhz
    After the agesa 1.2.0.0 bios update for Asus Strix-F B550, I could not increase the boost more than 200 mhz for my 5600x. It was possible with earlier bioses but the motherboard does not allow me to downgrade the bios either. I read that other brand boards also have this limitation with the latest bioses. I know that my cpu can boost to more than 4.85 ghz since I have a good optimized curve. Is this limitation a bug with new bioses or is it intentional? I think it should be up to the user to choose the boost.
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    166
    2,100
    Hello,
    Try entering a manual value under the AMD Overclocking Menu for PBO settings.
    New ROGer Array
    Feb 2021
    3
    Quote Originally Posted by Silent Scone@ROG View Post
    Hello,
    It is not possible to enter a manual value, that field is a combobox now with values from 0-200 mhz. I tried to leave it on zero and override it with the pbo boost field on the AI Tweaker section but it didnt boost past 200 mhz either.
    New ROGer Array
    Feb 2021
    3
    I am quite annoyed with this, I think there is a bug in the bios. Normally the value under AI Tweaker - PBO - Max CPU Boost Clock Override should "override" the value under AMD Overclocking - PBO - Max CPU Boost Clock Override, but it does not work. We need a new bios with this fixed, otherwise the only option to boost over 4.85 ghz is static overclocking, which requires lots of voltage to get stable.
