Results 1 to 9 of 9
    New ROGer Array
    Jan 2021
    2
    Maximus XII Apex (Z490) Flashback light won't turn on, can't boot
    Something is seriously amiss with my mobo. I can't switch from bios a, the flashback light won't turn on when I try to flash bios. I've removed ram, gpu, unplugged everything except the panel buttons and power (my system drive is an M.2 NVMe that's still installed). I've tried power off at the psu, unplugging psu, removing cmos battery for ten minutes, nada.
    I've already had to RMA this board once (was my fault, nothing against Asus) and I'd hate to have to try RMAing again.
    Any help would be most appreciated.
    ROG Guru: Green Belt Array geneo PC Specs
    geneo PC Specs
    Laptop (Model)13" Macbook Pro M1
    MotherboardROG Maximus XIII Hero (WiFi)
    Processori9-10900k 5.2 GHz AVX0 all core, 1.28v
    Memory (part number)64 GB G.Skill TridentZ RGB 4200 @ CL18
    Graphics Card #1Asus ROG Strix 2070 Super A8G
    Sound CardOn-board
    MonitorEIZO Coloredge CG2730 and Viewsonic QHD displays
    Storage #1Hynix 2TB P43, WDC SN850 1TB, Samsung 980 1TB
    Storage #21TB 850 x 1 TB 860 EVO RAID0, 6 TB WDC Black, 6TB IronWolf Pro
    CPU CoolerEK-AIO 360 D-RGB w/Phanteks T30 -120 fans, 1 Noctua Chromax 140 case fan
    CaseFractal Design Meshify 2 dark tint
    Power Supply750W Seasonic Prime Ultra Titanium Plus
    Keyboard Glorious GMMK TKL
    Mouse Logitech G305
    Headset Bose QC15
    Headset/Speakers Vanatoo T1, Klipsch R-12SWi Sub
    OS Windows 11 Pro X64, 22H2
    Network RouterAsus RT-AX82U + RT-AX86S mesh
    Accessory #1 Logitech c920e webcam
    Accessory #2 Sabrent DS-SC5B 5-Bay USB-C HDD docking station
    Accessory #3 xrite i1 Display monitor calibration
    geneo's Avatar
    Feb 2014
    115
    671
    I assume you have done this before and know of the naming convention for the BIOS file.
    Only thing I can suggest that you didn't mention to try is to reflash your current BIOS with an official BIOS using EZupdate.
    New ROGer Array
    Jan 2021
    2
    Correct, I used the renamer program and ensured the file is at the root of the usb.
    I can't get into bios so can't use ezupdate.
    ROG Enthusiast Array EncodeGR PC Specs
    EncodeGR PC Specs
    MotherboardAsus ROG Maximus XIII Hero
    ProcessorIntel Core i7-11700K
    Memory (part number)Kingston HyperX Predator RGB 32GB (4x8GB) DDR4 3600MHz CL17 Memory Kit - Black (HX436C17PB4AK4/32)
    Graphics Card #1MSI GTX 1070Ti Gaming X 8GB
    Sound CardCreative Sound Blaster Z
    MonitorDell Ultrasharp U2520D 25" QHD IPS
    Storage #1Samsung 980 Pro M.2 Nvme PCIe 4.0, 500 GB
    Storage #2Samsung 970 Evo Plus M.2 Nvme PCIe 3.0, 1 TB
    CPU CoolerNoctua NH-U12A
    CasePhanteks Enthoo Evolv X Glass - Black
    Power SupplyAsus ROG Thor 850W Platinum
    Keyboard Logitech G915 TKL Lightspeed, Tactile
    Mouse Razer Basilisk V2
    Headset Sennheiser Game-Zero Headset
    Mouse Pad Asus ROG Sheath XL
    Headset/Speakers Logitech Z333 2.1 Speakers
    OS Windows 10 Pro 64-bit
    Accessory #1 Noctua NF-A14 PWM (x6)
    Accessory #2 Phanteks Halos Lux
    Accessory #3 Phanteks Neon Digital-Rgb
    Feb 2021
    20
    55
    Is your usb drive properly formated ? (FAT32)
    geneo PC Specs
    Sound CardOn-board
    Mouse Logitech G305
    Headset Bose QC15
    geneo's Avatar
    Feb 2014
    115
    671
    Quote Originally Posted by Falconeer5 View Post
    Oh, you can't even boot your computer? Maybe RMA time, sorry. Read text not thread title.
    ROG Guru: Yellow Belt Array
    Dec 2018
    15
    138
    Hello ,
    Does your motherboard LED/Qreader ON ? or just everything without power ?
    rest everything [ unplug then plug everything ]
  7. #7
    geneo PC Specs
    Sound CardOn-board
    Mouse Logitech G305
    Headset Bose QC15
    geneo's Avatar
    Feb 2014
    115
    671
    Yeah, if the motherboard is getting power, maybe the flashback LED is dead. You could try pressing it , then waiting 5 minutes just to make sure.
  8. #8
    Dec 2018
    15
    138
    Quote Originally Posted by geneo View Post
    It's harder that QLED defective without reason .
  9. #9
    ROG Guru: Green Belt Array Saltgrass PC Specs
    Saltgrass PC Specs
    MotherboardMaximus Z790 Hero
    Processori9 13900K
    Graphics Card #1EVGA RTX 3090 FTW
    Sound CardOn Board
    MonitorDell AW3420DW
    Storage #1Samsung 980 Pro 2 TB
    Storage #2Samsung 860 Pro 1 TB
    CPU CoolerCooler Master Hyper 212X
    CaseCooler Master
    Power SupplyAntec HCP Platinum 1000
    Keyboard ASUS Strix Flare
    Mouse ASUS Chakram
    Headset/Speakers Logitech wired 5.1
    OS Win 11 Pro
    Network RouterROG Rapture GT-AX11000/AXE11000
    Accessory #1 VR Headset
    Accessory #2 Saitek X52
    Accessory #3 Intel AX411
    Jan 2014
    18
    660
    Could I just verify what you are attempting?
    You put the renamed Bios update on the flash drive and plug it into the correct USB port while the system is shut down.
    You then hold the Bios Flashback button for three seconds until the light blinks 3 times. The Clear CMOS light is the only light on on the back.
    If the system has two Bios chips, does it make a difference as to which one is chosen for booting?
    If the Bios update fails or leaves the system in an inoperable state, it can be recovered using the special CrashFree utility..
Tags for this Thread
