USB power on PRIME Z370-A
bobo1704
Hello!
Is there any way to disable USB power when the computer is off?
The "ErP Ready" is disabled, but there is no any USB power option to disable in "Onboard Devices Configuration" or anywhere else inside BIOS. Is there any other way except than disabling "Fast startup" inside Windows?
Thanks in advance!
Legolas
You can need to Set USB power delivery in Soft Off State (S5) to disabled.
Sincerely,
Legolas
