Results 1 to 4 of 4
    New ROGer Array
    Feb 2021
    2
    Asus SonicMaster boot sequence problem
    somehow i can't set the HDD of this device to first boot. it only shows USB as boot possibility. there's also is a section where i can set an adres to boot, but not sure what to fill inthere. anyone has a sollution to this?
    New ROGer Array
    Feb 2021
    2
    29 vieuws.... no answer
    ROG Guru: Orange Belt Array raju2529 PC Specs
    raju2529 PC Specs
    Laptop (Model)R542UQ-DM153 ( X542UQ.309SA )
    MotherboardAsus Builtin Motherboard X542UQ
    ProcessorIntel core i5 7200u @2.5Ghz
    Memory (part number)Adata 2400 Mhz 16GB DDR4
    Graphics Card #1intel HD 620 graphics 1GB DDR3 DCH WHQL driver v.30.100.9667
    Graphics Card #2Nvidia GeForce 940MX 2GB GDDR5 DCH WHQL driver v30.0.14.7076
    Graphics Card #3nil
    Graphics Card #4nil
    Sound CardRealtek HD Audio controller with codec ALC294 WHQL driver v6.0.9151.1
    MonitorBuiltin Lcd monitor model BOE
    Storage #1Samsung 850 Evo 1000GB SSD M.2. 2280
    Storage #2Seagate 2TB 2.5inch 5400rpm and Seagate 2TB 2.5inch 5400rpm2.5 inch
    CPU CoolerBuilt-in
    CaseFrom factory
    Power Supply65W
    Keyboard Built in keyboard
    Mouse Built in mouse
    Headset Purchased Philips HeadSet
    Mouse Pad nil
    Headset/Speakers Realtek Builtin Speakers
    OS Windows 10 Enterprise 64bit v21H1 build no 19043.1055
    Network RouterNextVision ONU Fiber Modem
    Accessory #1 G40 Wired Gaming Mouse
    Accessory #2 Laptop Cooling table with fan
    Accessory #3 Secureye Usb finger print scanner added seperately for Windows Hello
    raju2529's Avatar
    Feb 2018
    9
    362
    at first we use usb pendrive to install windows os to HDD .while installing windows os, windows will Assign 100MB for boot files to copy in first partition with fat32 format type..
    second partition does not Assign drive letter but takes 16MB for MSR files.
    In third partition , windows will install with NTFS format.
    I need some screenshots to verify In your HDD boot partition is created or not.
    If boot partition is created in HDD as first partition means then you can set boot device as HDD , otherwise you cant set.
    Moderator Array
    Feb 2019
    14
    716
    Hello Fenrir,
    Which model do you have?
