Results 1 to 5 of 5
    ROG Member Array
    Mar 2021
    11
    24
    Overclocking beginner needs some advice
    Hi all,
    This is my first time to overclock my new rig.
    I just got an AMD 5800x after waiting for three months. I have Dark Hero mobo.
    I tried many different manual/auto options and I cannot get past 4.6G for all-core OC.
    I tried VCore Offset and set the value to "Auto". The VCore shot up to over 1.6V. I was worried about the degrading of my CPU though.
    After spending the whole week and weekend in OC, I ended up with a satifactory OC at both single-core and all-core. The JPG shows the result in Cinebench R23.
    I would like to have any suggestions and advices to put the performance further.
    Thanks,
    GTDragon
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    178
    2,299
    Hello,
    Overclocking on this platform is quite limited. Enable DOCP and PBO and use the system as you intended. You can experiment with curve optimiser which can be found under the AMD Overclocking menu. Aim for a negative value to reduce voltage. High voltage at low load is normal on this architecture, if you're monitoring you should see the vcore drops substantially under high current loads. It is current that degrades chips quickly.
    ROG Member Array
    Mar 2021
    11
    24
    Quote Originally Posted by Silent Scone@ROG View Post
    Hello,
    Thank you for your reply.
    Yes, I did enable DOCP to overclock my RAM from C16-3600 to C16-4000, and enable PBO and curve optimizer. I left everything else to Auto and it gives me pretty stable performance.
    I did try to tweak different setting manually but the system is not stable either under all-core or single-core OC though.
    Thanks,
    GTDragon
    Mar 2016
    178
    2,299
    Quote Originally Posted by isaactwn View Post
    Thanks,
    GTDragon
    Yes, pushing things to the limit is the overclockers disposition, but there isn't much headroom here sadly. You can experiment with some third party tuning tools, however these often impact single threaded workloads.
    ROG Member Array BuddyW PC Specs
    BuddyW PC Specs
    MotherboardTUF B550m-Plus
    Processor3700X
    Memory (part number)GSkill 3200: F4-3200C14-8GFX
    Graphics Card #1Power Color RX5700XT Red Dragon
    Sound CardRealtek S1200a
    CPU CoolerCoolerMaster LM240
    CaseCoolerMaster N200
    Power SupplyCorsair RM650x
    OS Win10 Pro
    May 2021
    21
    23
    Thanks,
    GTDragon
    I find 'tweaking' to be an endless source of fun and educating too, especially if you can actually see the benefit in performance. As noted, Ryzen's have very little conventional overclocking headroom because of how the boosting algorithm works so that way of doing it winds up just being frustrating.
    But that doesn't mean you have to stop tweaking. There's a lot you can do with PBO and the curve optimizer...
    https://hothardware.com/reviews/amd-...er-guide-zen-3
    and a very good youtube:
    https://www.youtube.com/watch?v=dfkrp25dpQ0
    I like wasting time by tweaking at my setup too, i only wish I had a 5000 (I have a 3700x) to see just how this one works.
