Results 1 to 5 of 5
    ROG Member Array
    Nov 2020
    9
    Angry ASUS ROG Delta Mic Problem FW 0141
    Hello my ROG Delta I updated new FW (0141) but microphone not working only working on 0039_beta. But now i couldn't fix it that way. I downgraded my ROG Delta firmware to 0039_beta that can be downloaded from the support site. And that fixed it. Please fix it soon...
    Thanks.
    New ROGer Array
    Feb 2021
    3
    Quote Originally Posted by mysquen View Post
    Thanks.
    Not allowing this FW (0141) microphone can also cause this problem, you should try it once. Because if there is a malfunction in the microphone, the 0039 may not work properly even on beta.
    You must check your microphone before fixing it. Similarly with microphone problem, you can check your mic using some site. Which explains the characteristics of your mic with your mic as well as helps to solve your problem, I have a few sites that I would like to share with you https://mictests.net.
    Mastermind19 Array
    Oct 2015
    121
    Thanks.
    What Delta do you have?
    If you have Delta, please download and update firmware - https://dlcdnets.asus.com/pub/ASUS/A...dset_V0045.zip
    Sincerely,
    TY
    ROG Member Array
    Nov 2020
    9
    Quote Originally Posted by ConnieHruska View Post
    Still same issue not working to new firmware 0045, only works perfectly 00_39 beta
    same issue microphone not working on discord or windows voice recorder like other programs but same bro same..
    ROG Enthusiast Array sefiremre PC Specs
    sefiremre PC Specs
    Laptop (Model)ASUS G751JY DH-71
    MotherboardASUS Z87-PLUS
    ProcessorIntel i7 4770K
    Memory (part number)Gskill 4x4Gb Ripjaws Ddr3 1600Mhz Cl9 1.5V
    Graphics Card #1ASUS GTX780 DCU II
    Graphics Card #2ASUS GTX 580 DCU II
    Sound CardSOUND BLASTER Zx
    MonitorBENQ XL 2420T
    Storage #1SAMSUNG EVO840 500 GB
    Storage #2SAMSUNG EVO850 500 GB
    CPU CoolerCOOLER MASTER SEIDON 120XL
    CaseCOOLER MASTER HAF942 BT
    Power SupplyCORSAIR CX MODULER 750
    Keyboard CORSAIR K70 MECHANICAL
    Mouse ASUS CLAW - LOGITECH G502
    Headset ASUS STRIX DSP
    Mouse Pad LOGITECH G240
    Headset/Speakers EDIFIER S730
    Network RouterASUS N12LX
    Jun 2015
    38
    I have same problem before its work well but a day its gone cant detecting mic input is working but output not working when i try to setting from Recording Settings its not opening when i plug of settings are opening but on my lap top its working i dont understand its totally frimware problem i guess anyone solve it ?
Tags for this Thread
