Asus rog g752 vm single click and left click
Arty03
I had this laptop for a long time and decided to update it to the latest build change the ram
and install an nvme drive to speed it up.
Problems at first the bios disabled a function "internal pointing device"
there was no function at all with the touch pad .. after it was enabled
it started working well half of it … left click and single click
don't work tried deleting windows and re installing it again downloaded
the touchpad drivers from ASUS website and they didn't worked
downloaded drivers from this ivanrf.com site that he updates all ASUS drivers
didn't work either (when i meant single click i meant double tab doesn't work either)
Problemas so far:
single click and left click dont work
asus driveers installed :
atk build 1.0.0061
asus gesture 4.0.24
ptp 11.0.10
os build : windows 10 : 19042.870
tried with another drive with windows 10 and it works the only difference is the drive same windows same build but no ASUS drivers
after installing the windows 10 image that i got from microsoft they didnt work either so i had to get a wired mouse.
0 REPLIES 0
