Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    ROG Member Array pdixon0 PC Specs
    pdixon0 PC Specs
    MotherboardASUS ROG STRIX Z590-E GAMING WIFI
    ProcessorIntel Core i7-11700K
    Memory (part number)G.Skill Trident Z RGB 3733MHz 32GB (F4-3733C17D-32GTZR)
    Graphics Card #1ASUS ROG STRIX 3070 Ti O8G Gaming OC
    Monitor3x HP LA2405x
    Storage #1WD SN850 500GB
    Storage #2AData SX8200 Pro 2TB (early version)
    CPU CoolerNoctua NH-D15 Chromax.Black
    CaseAntec P120 Crystal
    Power SupplyCorsair RM750i
    Keyboard Steelseries Apex 3
    Mouse Steelseries Sensei 10
    Headset Steelseries Arctis 1
    Headset/Speakers Creative 8200
    OS Win 10 Pro x64
    Network RouterSky SR203 and BT Hub6 used as switch
    Accessory #1 6 x Noctua S12A Chromax.Black case fans
    Accessory #2 2nd Noctua NH-D15 fan used as case exhaust just behind the 2nd tower
    Mar 2021
    18
    Question ROG STRIX Z590-E Gaming WiFi overclocking 10700K
    Hi guys
    I'm hoping for a little guidance here!
    I've recently upgraded my motherboard from a Z490 PRIME-A to a ROG STRIX Z590-E Gaming WiFi. The old motherboard has gone to a build for my son.
    OK, on the PRIME-A I used to run my 10700K at the following and it was stable with decent temps in AIDA64 (~92C) after 10 mins or so.
    MCE - Enabled
    Core Usage - 52, 52, 52, 52, 51, 51, 51, 51
    AVX Offset - 1
    SVID - Best Case Scenario
    LLC - 4
    Adaptive Voltage - 1.4V
    VCCIO - 1.2V
    VCCSA - 1.2V
    DRAM - 1.4V
    DRAM Speed - 4000MHz
    Vcore in HWiNFO64 would max out at around 1.459V which I believe being socket sense would really be around 1.36-1.37V which I was quite happy with, again the temps were managable.
    There were probably some other tweaks like TVB Voltage Optimizations being enabled too...
    Now with the new board, to get it to even boot into Windows I need to run Adaptive Voltage at 1.58V which is obviously not a happy place to be! Mind you, HWiNFO64 maxes out at around 1.476 or something like that, which 'should' still be just less than 1.4V if you take into account that it is a Socket Sense reading?
    I know the voltage isn't really high as the temps stay around the same ~92C in AIDA64 but I'm not happy that I'm having to use such a high value in BIOS, just in case!
    What are everyone else's findings on the Z590 boards? I know they're still immature BIOS-wise - I'm currently on 0605
    My full build for info:
    10700K (SP in BIOS 51)
    Noctua D15 Chromax.Black (Cooler Score in BIOS ~182)
    32GB G.Skill Trident Z RGB 3733MHz
    Corsair RM750i
    WD SN850 500GB boot SSD (in slot 3)
    AData Sx8200Pro 2TB (the one with the good controller etc in slot 4)
    EVGA 1070 Ti FTW2 (+550MHz RAM / +200MHz core)
    Antec P120 Crystal
    6 x Noctua Chromax.Black S12A Case fans
    Thanks in advance
    Paul Dixon
    pdixon0 PC Specs
    OS Win 10 Pro x64
    Mar 2021
    18
    I've now picked up a 11700K and even with Optimized Default settings I'm seeing way over 1.5V in HWinfo64 VCore???
    I've just changed Adaptive Voltage to 1.4V, only other changes are XMP1 - DDR4 3733MHz to match my RAM kit, everything else on Auto - seeing 1.545V VCore in HWInfo64???? Not sure what Auto LLC is but this can't be right?
    I'm in process of RMA'ing my 10700K but I have a feeling it's not the CPU it's the board???
    I've tried new BIOS 0703 and now 0704 with the same results.
    SP for the 10700K is 51 and the SP for the 11700K is 55 so yeah, I've lost out on the SL both times however the 10700K would run at the settings in my previous post nice and stable in games etc on my PRIME Z490-A board, this STRIX Z590-E should be a better board???
    (*HwINFO64 version 7.00-4400 in use - the beta version 7.01-4425 shows VCores over 2.75V which is obviously wrong)
    Super Moderator Array
    Jul 2011
    95
    768
    setting adaptive to 1.4v does nothing if it is a value lower than the native vid
    you can read up:
    https://rog.asus.com/forum/showthrea...ons-and-others
    as for native vid viewing, see it in v/f pt offset menu
    pdixon0 PC Specs
    OS Win 10 Pro x64
    Mar 2021
    18
    Thanks @Shamino, I'd actually read that when I first got back into overclocking last year.
    What I don't understand is the massive voltage requirement difference between my PRIME-A Z490 and this STRIX Z590-E? 0.18V in BIOS for the same chip can't be right?
    Is it the case that HWiNFO64 simply can't read the right VCore on the Z590 board yet? I'm assuming both boards are Socket Sense and that the VCore displayed in HWiNFO64 is around 0.08-0.09V higher than what the CPU is actually seeing?
    And surely, if either chip was really pulling 1.5+V, I'd not be able to keep it at a decent temperature with an NF-D15????
    Having said that, having to set 1.58V in BIOS for the same chip that only need 1.4V on the other board makes me think it's the board itself that is out???
    pdixon0 PC Specs
    OS Win 10 Pro x64
    Mar 2021
    18
    Can I please ask everyone running a Z590 board what their BIOS VCore settings are? Please mention your processor, stock or OC, and board?
    ROG Enthusiast Array GObonzo PC Specs
    GObonzo PC Specs
    Laptop (Model)Lenovo IdeaPad G780
    MotherboardROG Strix Z590-E Gaming
    Processori7-11700K @5.2GHz
    Memory (part number)F4-3200C14D-32GTZSK-G.SKILL
    Graphics Card #1ASUS TUF RTX 3080 Ti
    MonitorAlienware AW3420DW (34" 3440x1440p)
    Storage #1M.2 NVMe: 2x MP510 512GB \ 2.5" SATA III: 1x 4TB, 1x 1TB
    Storage #2external HDs: 16TB
    CPU CoolerASUS Ryujin 360
    CaseFractal Design Vector RS (5x be quiet! Silent Wings 3 140mm High-Speed PWM)
    Power SupplySuper Flower Leadex III 850w Gold
    Keyboard Corsair K70 LUX RGB — CHERRY® MX RGB Brown
    Mouse Logitech G600, Corsair Vengeance M95
    Headset Soundcore Q20 Life
    Mouse Pad 24" x 12" extended
    Headset/Speakers Klipsch ProMedia 2.1
    OS Windows 10 x64 Pro
    Network RouterWAVLINK AC1200
    Accessory #1 Microsoft XBOX One S Gamepad
    Accessory #2 ASUS USB 2.0 DVD-RW (SDRW-08D2S-U)
    Accessory #3 LG CX 55" TV
    GObonzo's Avatar
    Apr 2019
    56
    using the Z590-E Gaming WiFi & 11700K;
    BIOS(0704) with default settings, shows Vcore @ 1.465v.
    still with defaults, HWinfo under CPU drop-down shows voltage min @ .63v \ avg @ 1.36v \ max @ 1.47v.
    under Motherboard drop-down shows max Vcore @ 2.57v.
    setting Cores to 5.2GHz, i can't boot OS with anything under 1.455v.
    and then it wasn't stable when stressing.
    1.5v is the lowest i can go so far stable @ 5.2GHz.
    seems crazy. my 8700K on the Z370 version of this board @ 5.2GHz runs perfectly @ 1.285v.
    but all the early articles i saw about the 11th gen stated they were power hungry.
    ASUS ROG Strix Z590-E Gaming | i7-11700K \ ASUS ROG Ryujin 360 | G.Skill TridentZ 3466 CL14 32GB | ASUS TUF RTX 3080 Ti | M2: 960GB \ SSDs: 5TB \ HDs: 16TB | Super Flower Leadex III 850w | Fractal Design Vector RS Blackout \ 5x be quiet! Silent Wings 3 140mm High-Speed PWM | Logitech G600 | Corsair K70 LUX RGB | Xbox One S Gamepad | Klipsch ProMedia 2.1 | Anker Soundcore Life Q20 | 34" Alienware AW3420DW \ 55" LG CX OLED | Windows 10 Pro x64
  7. #7
    pdixon0 PC Specs
    OS Win 10 Pro x64
    Mar 2021
    18
    Hey GObonzo
    Sounds like you're having a similar experience to me? Have you got Adaptive Boost enabled by any chance? I think this is what causes the additional voltages?
    I've been able to get a 52, 52, 50, 50, 49, 49, 49, 49 overclock set at 1.45V Adaptive in BIOS with ABT and TVB disabled at LLC5, pulls VCore of just over 1.4V in HWiNFO64 on load now which I'm happy with (I believe this is around 1.32V in reality with it being a Socket Sense reading?). I've also set AVX2 -2 and AVX512 -4.
    My 11700K is only an SP55 and my V/F curve isn't great unfortunately, needs 1.433V for 5.0GHz according to the tables. Might see if I can get it to 52, 52, 50, 50, 50, 50, 50, 50 at 1.45V
  8. #8
    GObonzo PC Specs
    GObonzo's Avatar
    Apr 2019
    56
    i decided to see how well ASUS may have adapted their AI Overclocking for the new generation and it works okay.
    after a couple stress tests and restarts, ended up with 5.1GHz on all cores with zero AVX offset @ 1.469v.
    though it raised my temps ~10° at 100% usage and it disables all c-states which also sucks.
    while it is getting better implemented, I still wouldn't use it as a "set & forget it" method of overclocking.
  9. #9
    New ROGer Array
    Apr 2018
    3
    10700k OC
    I have the same CPU-M/B and my OC settings are these:
    Ai OC Tuner: XMP II
    ASUS MCE : Disabled
    CPU Core Ratio: Sync All Cores
    AVX: Auto
    All Core Ratio Limit: 50
    CPU SVID Support: Disabled
    Ring Down Bin: Enabled
    Min CPU Cache:43
    Max CPU Cache:43
    CPU Core/Cache Voltage: Manual
    CPU Core Voltage Overide: 1.32
    CPU LLC: 4
    CPU Thermal Control : 125
    CPU Core/Cache Limit Max: 255,75
    Long Duration Package Power Limit - 4095
    Short Duration Package Power Limit - 4095
    IA AC Load Line : 0.01
    IA DC Load Line: 0.01
    Memory: 3200
    All the rest are set to AUTO...
    Have run CineBench r20&r23 , Prime95 for about an hour (small fft - no avx) , with latest BIOS , and it seems stable with Dark Rock Pro 4 max temps ~75C.
  10. #10
    pdixon0 PC Specs
    OS Win 10 Pro x64
    Mar 2021
    18
    1.32V VCore?! I couldn't even get my 10700K to POST with less than 1.5V adaptive in BIOS! I've since moved on to a 11700K and that is fine at 1.45V adaptive (LLC5). Don't know if it has been a newer BIOS (0704) or if there were some strange settings in BIOS that the 10700K didn't like. It ran like a champ on the Z490 board I have...
Tags for this Thread
