ROG Rampage VI Extreme Omega USB ISO
Counteragent
Hi Guys,
I've misplaced my original USB key I got with the motherboard, was wondering if there's an ISO / image that can be downloaded?
Cheers
MB: ASUS Rampage V Extreme
CPU: Intel Core i7 5960X Extreme Edition
RAM: Dominator® Platinum Series 32GB (4 x 8GB) DDR4 DRAM 2800MHz
PSU: Corsair AX1200i Digital ATX Modular
GFX: 3 x EVGA GTX Titan Black Superclocked 6GB
SSD: 2 x Samsung 850 Pro Series 512Gb SSD Raid 0
HDD: 2 x WD4003FZEX WD Black 4TB Raid 0
1234;
2 x WD1000DHTZ WD VelociRaptor 1TB Raid 0
MON: Dell Ultra Sharp 32 Ultra HD Monitor - UP3214Q
CASE: Silverstone Temjin TJ11 Black with Window Case
OS: Win7 x64bit
G75rog
Did you check ASUS Support for your board?
BigJohnny
You are better off getting the drivers off the support page. Whats on the USB is always outdated and you end up having to update everything. I always just download what I need onto a different PC then put them on a USB stick. One piece of advice that they dont tell you. As soon as you have windows installed do the chipset drivers first followed by the Intel MEI then reboot then install the rest in whatever order you want. Get the graphics driver off the manufacturers website.
Also if you know which Realtek solution you have get that from realtek and same for ethernet etc.
Station drivers is a good resource for drivers that often have more updated drivers than the manufacturer.
