Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    ROG Member Array
    Mar 2021
    11
    8
    ROG ZEPHYRUS DUO 15 SE 3080 is not detected in AURA Creator v2.2.5
    My Laptop ROG ZEPHYRUS DUO 15 SE 3080 GX551QS is not detected in AURA Creator v2.2.5.
    Already fresh installed armoury crate installer and fresh installed windows.
    Item Version
    Armoury Crate UWP App 4.0.8.0
    ROG Live Service 1.2.5.0
    AURA Service (Lighting Service) 3.04.35
    Armoury Crate service 4.0.12
    ASUS Mouse HAL 1.1.0.45
    ROG Member Array
    Apr 2021
    9
    Same Issue
    I'm having the exact same issue with my GX551QM (3060 version). I tried literally every possible thing (ranging from clean uninstalls and also installing the old Aura Lighting software to complete format) to make this thing work so I could use Aura Lighting in Ghostrunner, but NO, nothing makes the software recognize this laptop's RGB keyboard.
    We need an URGENT FIX, ASUS.
    ROG Member Array
    Apr 2021
    9
    ROG Zephyrus Duo 15 SE GX551QM Not Detected In Arm. Crate Aura Sync and Aura Creator
    The title says it all.
    I bought this laptop with a price tag that led me to expect perfection, but I'm having major software issues with it.
    Since Armoury Crate doesn't recognize the RGB keyboard in the Aura Sync and also in the Aura Creator software, I'm left out of all the possibilities this per key RGB keyboard can offer.
    I used the Armoury Crate Uninstall Tool to clean uninstall and reinstall it at least 6-7 times. I even resorted to installing the old Lighting Control software found in the ASUS Aura page as the legacy software.
    Nothing helped, so I formatted my PC (also due to some other graphics and audio driver issues). I even formatted 3 times, but no. Armoury Crate won't recognize my keyboard within the Aura Sync tab.
    I installed all the latest drivers from the scratch and updated them daily. Other people using the same laptop also reported the same issue here.
    ASUS, we need a software fix for this issue, ASAP.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    344
    8,023
    *****Consolidated duplicate threads. Please use existing threads where possible. Thanks.****
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Member Array
    Mar 2021
    11
    8
    Now , Armoury Crate is able to detect and control my Labtop but Aura Creator is not even able to detect it. Please help
    System = Windows 10 Pro 20H2 OS build 19042.906
    AURA Creator Version 2.2.5
    Item Version
    ASUS Aac_NBDT HAL 2.4.7.1
    ASUS Keyboard HAL 1.01.41
    ASUS MB Peripheral Products 1.0.35
    AacAudioHal 1.3.20.0
    AacDispaly 1.1.29
    ROG Member Array
    Apr 2021
    9
    Quote Originally Posted by mama5bath View Post
    Item Version
    AacDispaly 1.1.29
    Hey, how did you make it so that your Armoury Crate Aura Sync recognized your laptop? I really don't care much about Aura Creator but I need Armoury Crate Aura Sync to recognize my laptop so I can sync it with games that support Aura such as Ghostrunner. Can you give me any advice how to make Armoury Crate recognize the laptop? Thanks.
  7. #7
    ROG Member Array
    Mar 2021
    11
    8
    Quote Originally Posted by PrivateBlood View Post
    In the eSupport folder at C:drive, I tried the installation as follows and restart
  8. #8
    ROG Member Array
    Apr 2021
    9
    After having extreme issues with the audio and video drivers, I had to format my PC several times, and eventually I also removed all the ASUS preinstalled drive partitions. It actually never crossed my mind that some older driver files would be required so that my keyboard would function properly. I might get lucky with a lost file recovery program, but if that wouldn't be much of an inconvenience to you, could you upload this folder to Drive, Mega, etc. and share it with me either here or via PM? I would be very grateful. Thank you.
  9. #9
    ROG Member Array
    Mar 2021
    11
    8
    Please check your inbox
  10. #10
    ROG Member Array
    Apr 2021
    9
    THANK YOU! Thank you so much for providing me with the complete eSupport drive partition.
    I followed your very eloquent instructions and ran the install.bat and BAM! Armoury Crate started to recognize my PC!!! I am finally able to use Aura Sync. I immediately tried it out with the Ghostrunner game and the lighting effects worked as advertised.
    Thanks to you, I'm very happy right now.
    To be able to provide some information to you, I reinstalled the Aura Creator and checked, but as in your case, my Aura Creator also still doesn't recognize the laptop. I have no use for Aura Creator as I typically use the Reactive Key option that makes the keys light up as I press them (which has its own issues that I still am unable to fix; like some keys not reacting and ROG key lighting up the PgUp switch key instead), but I hope ASUS steps up and provides you with help that fixes this Aura Creator recognition issue.
Tags for this Thread
