G512LV Missing Panel Overdrive option 3ms in armoury crate Refresh Rate Service fail
Voldemort
Recenlty I just learn about the 3ms option that it has to be activated via armoury crate software. I installed the missing service and all needed stuff but still no 3ms overdrive option in system configuration tab in armoury crate. Iam using G512LV. Restarting the service does nothing. Reinstalling more than 10 times still does not appear in armoury crate. Installed OEM windows particularly for my model, still can't manage to run panel overdrive. Please ASUS fix your software !
9 REPLIES 9
Voldemort
I got 6.4ms... I need 3msImage
I somehow managed to get the panel overdrive showing for the first time ever in armoury crate. I did reinstall windows 2 times, installed the service and then armoury crate. Now is showing but seems that is not working in services menu, and when I try to turn the service its giving the error shown in the photo.
Blake1
Hi there,
What's your Armoury Crate and Refresh rate service version?
https://rog.asus.com/laptops/rog-strix/rog-strix-g15-series/helpdesk_download
Blake@ROG wrote:
Hi there,
Iam using all latest versions available. Now I have the option available for toggling but it seems its not working, no matter how many times Iam toggling it. If I turn it off for example when I switch tabs in armoury crate ( for example going to aurasync tab) when I go back to main 3ms overdrive turns itself on...
Blake@ROG wrote:
Hi there,
I really need some help solving this problem please tell me what should I do.
Blake@ROG wrote:
Hi there,
I really need to hear feedback from you, I need to know what to do. The feature is definitely problematic and I need to know how to resolve this problem. Should I wait for update in armoury or of the service refresh rate only, should I install auditional application, service.
Voldemort
SOLVED! The model I got doesn`t support 3ms, thats why toggling it nothing happens. 3ms i supported saddly on over 144hz laptop displays 🙂
AstraL154
