The 5G_1 radio is a 2x2 radio and uses the 160 MHz bandwidth. I will normally, when close to the router, get a 2402/2402 Mbps Link speed.
There is always a chance something is faulty, but lets hope not. Do you have any other Wi-Fi 6 capable devices, like phones?
The ability for a 5 GHz signal to travel large distances and penetrate walls is less then the 2.4 GHz band. So you might move the laptop around and change it orientation to the router to see if the signal strength increases from location to location.. Once you verify what link speed you get when in close proximity to the router, maybe we can look for other causes.
Maximus Z790 Hero,
Intel i9-13900k
Intel BE200
