G732LWS frame drop (CPU frequency drops to 801 Mhz) - solved
maicol07
I have a Scar Strix G732LWS and I get frame drops while playing (more evident with Assassins Creed Odyssey). Examining with MSI Afterburner while I play, I've found out the CPU drops to 801 mhz from its normal speed when it is near 100°C. Since I play with the Turbo mode enabled in Armoury Crate this shouldn't happen and temps shouldn't raise so much. Is there a way to fix this?
Thanks
Normal speed/frequency:
88210
Blake1
Hi there,
Would you mind to switch to Manual mode and put the fan to full speed?
The temperature is a bit high, maybe we can do some fan cleaning or put the laptop to a better heat radiation position then see if it gets better?
Blake@ROG wrote:
Hi there,
The fix was fan cleaning. Thank you
