Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Guru: Yellow Belt Array zocker PC Specs
    zocker PC Specs
    MotherboardROG STRIX Z490-H GAMING
    Processori9-10850K
    Memory (part number)32GB Corsair Vengeance LPX
    Graphics Card #1RTX 3090 Founders Edition
    Sound CardSound Blaster ZxR
    MonitorAcer Predator XB273K
    Storage #1Samsung 960 EVO NVMe M.2
    Storage #2Samsung 860 EVO 2TB
    CPU CoolerNoctua DH15-S
    CaseENTHOO 719
    Power Supplybe quiet! Dark Power Pro 11 1000W
    Keyboard Corsair K65 Rapid Fire
    Mouse ROG Gladius II
    Mouse Pad HyperX HX-MPFS-S-L FURY S Speed Edition Pro
    OS Windows 10
    Network RouterFritzbox 6590
    zocker's Avatar
    Jul 2016
    138
    Downgrade Intel ME Firmware?
    Is it possible?
    i9-10850K
    Samsung SSD 960 EVO 250GB
    Sound Blaster ZxR
    ROG Member Array
    Aug 2015
    23
    18
    Technically yes, but it's quite a process. I've read about it on the win-raid forums and it involves buying a chip and stuff - real pain the ass.
    But for most people, the answer is a big fat NOPE.
    ROG Guru: Green Belt Array geneo PC Specs
    geneo PC Specs
    Laptop (Model)13" Macbook Pro M1
    MotherboardROG Maximus XIII Hero (WiFi)
    Processori9-10900k 5.2 GHz AVX0 all core, 1.28v
    Memory (part number)32 GB G.Skill TridentZ RGB 3200/CL14 @ 4100 16-16-34
    Graphics Card #1Asus ROG Strix 2070 Super A8G
    Sound CardOn-board
    MonitorEIZO Coloredge CG2730 and Viewsonic QHD displays
    Storage #1WDC SN850 1TB, Samsung 980 1TB
    Storage #21TB 850 x 1 TB 860 EVO RAID0, 6 TB WDC Black, 6TB IronWolf Pro
    CPU CoolerEK-AIO 360 D-RGB w/Phanteks T30 -120 fans, 1 Noctua Chromax 140 case fan
    CaseFractal Design Meshify 2 dark tint
    Power Supply750W Seasonic Prime Ultra Titanium Plus
    Keyboard Glorious GMMK TKL
    Mouse Logitech G305
    Headset Bose QC15
    Headset/Speakers Vanatoo T1, Klipsch R-12SWi Sub
    OS Windows 11 Pro X64
    Network RouterLinksys EA7300
    Accessory #1 Logitech c920e webcam
    Accessory #2 Sabrent DS-SC5B 5-Bay USB-C HDD docking station
    Accessory #3 xrite i1 Display monitor calibration
    geneo's Avatar
    Feb 2014
    93
    649
    You can if the ME SVN hasn't changed. The SVN number determines if you can roll back to. Intel clicks it up in new firmware if they need to prevent downgrade. if the SVN are the same you should be able to. Otherwise it is an ordeal as mentioned.
    zocker PC Specs
    Processori9-10850K
    CaseENTHOO 719
    OS Windows 10
    zocker's Avatar
    Jul 2016
    138
    Thank You for the Answers!
    The thing why i am thinking about a Downgrade is the following Stuff:
    TurboV Core 1.10.07 says "Please install Intel MEI Driver from ASUS Support CD."
    And sometimes AISuite3 says too that the MEI Driver is not installed.
    I have Windows reinstalled and same "Error" but System runs fine.
    And why is a 1# after the Intel MEI Driver?!
    I tried different Versions but all the same.
    The FW is Unknown
    I have flashed the latest FW from here.
    https://rog.asus.com/forum/showthrea...ntel-ME-(Z490)
    i9-10850K
    Sound Blaster ZxR
    geneo PC Specs
    Sound CardOn-board
    Mouse Logitech G305
    Headset Bose QC15
    geneo's Avatar
    Feb 2014
    93
    649
    Your firmware version is not unknown. Only the date and manufacturer. It is 14.1.53.1617.
    The #1 has been there for a while. I don't know why but it is normal.
    What version of the driver do you have (in the (driver tab of the Intel management Interface #1)? sounds more like a driver/app issue.
    Have you tried the ME driver from the Asus support page for your board?
    Why don't you post this question in the thread that you got the firmware from.
    geneo PC Specs
    Sound CardOn-board
    Mouse Logitech G305
    Headset Bose QC15
    geneo's Avatar
    Feb 2014
    93
    649
    Out of curiosity. I did look into the #1 in the Device display name. Looking at the inf file, the #n is used to distinguish between different Intel Management Engine flavors. For instance there is a tiger lake variant that has no components (DAL or LMS) that would get a #3.
    All Z490 Comet lake 14.x are Intel(R) Management Engine Interface #1
  7. #7
    Feb 2019
    129
    712
    Quote Originally Posted by zocker View Post
    The FW is Unknown
    This isnt an MEI issue, its an ASUS software issue. Just another reason I don't run AI suite, Armory Crate or anything else by ASUS. They make great hardware but the software just plain sucks.
  8. #8
    geneo PC Specs
    Sound CardOn-board
    Mouse Logitech G305
    Headset Bose QC15
    geneo's Avatar
    Feb 2014
    93
    649
    I run AISuite fine with that version of ME firmware and the latest ME drivers . Never had a problem. Not once in many years across many platforms. It is one of the most stable Asus applications.
  9. #9
    zocker PC Specs
    Processori9-10850K
    CaseENTHOO 719
    OS Windows 10
    zocker's Avatar
    Jul 2016
    138
    Thanks for the Answers!
    Quote Originally Posted by BigJohnny View Post
    Then i hope the Supreme Software-Support of ASUS will fix it.
    Quote Originally Posted by geneo View Post
    Yes youre right, the FW isnt unknown, but the Date is unknown.
    I tried different Versions from the Support Page.
    i9-10850K
    Sound Blaster ZxR
  10. #10
    New ROGer Array
    Jan 2022
    2
    I apologize for a probably very dumb version, but how do I know/find this security number? For instance, is it the same between 14.1.53.1649 and 14.1.65.1969? If yes, how do I downgrade? I've got a Z490. Thank you
    p.s.
    Should I compare TCB or ARB? Or both should match?
