Results 1 to 3 of 3
    New ROGer Array
    Feb 2021
    4
    Undervolt 11900KF
    I have a Maximus Xiii Hero and want to undervolt for lower temps.
    Is it possible?
    ROG Enthusiast Array EncodeGR PC Specs
    EncodeGR PC Specs
    MotherboardAsus ROG Maximus XIII Hero
    ProcessorIntel Core i7-11700K
    Memory (part number)Kingston HyperX Predator RGB 32GB (4x8GB) DDR4 3600MHz CL17 Memory Kit - Black (HX436C17PB4AK4/32)
    Graphics Card #1MSI GTX 1070Ti Gaming X 8GB
    Sound CardCreative Sound Blaster Z
    MonitorDell Ultrasharp U2520D 25" QHD IPS
    Storage #1Samsung 980 Pro M.2 Nvme PCIe 4.0, 500 GB
    Storage #2Samsung 970 Evo Plus M.2 Nvme PCIe 3.0, 1 TB
    CPU CoolerNoctua NH-U12A
    CasePhanteks Enthoo Evolv X Glass - Black
    Power SupplyAsus ROG Thor 850W Platinum
    Keyboard Logitech G915 TKL Lightspeed, Tactile
    Mouse Razer Basilisk V2
    Headset Sennheiser Game-Zero Headset
    Mouse Pad Asus ROG Sheath XL
    Headset/Speakers Logitech Z333 2.1 Speakers
    OS Windows 10 Pro 64-bit
    Accessory #1 Noctua NF-A14 PWM (x6)
    Accessory #2 Phanteks Halos Lux
    Accessory #3 Phanteks Neon Digital-Rgb
    Feb 2021
    20
    55
    Hey there,
    Undervolting without underclocking will lead to instabilities.
    You may be able to do it a little bit, it's generally recommended though to underclock too.
    In general for overclocking/underclocking you have 3 options.
    1. Manual Core Voltage + Sync All Cores
    All cores will be synced to your preffered ratio (lower ratio for underclock).
    All cores will run at your fixed/static core voltage. (lower voltage for undervolt)
    Example: All-Core 42x @ 1.15v (static voltage)
    2. Auto Core Voltage + Sync All Cores
    All cores will run on a automatically controlled voltage. (lower voltage for undervolt)
    Example: All-Core 42x @ 0.60 - 1.15v (dynamic voltage)
    3. Auto Core Voltage + By Core Usage
    All cores will be synced to the ratio specified by the core-usage, chosen by you. (lower ratio for underclock).
    That means that the ratios will change basen on how many core are used.
    Example: 45x-45x-44x-44x-43x-43x-42x-42x @ 0.60 - 1.15v (dynamic voltage)
    ** (values and voltages are just an example, they are not valid) **
    When Auto Core Voltage is chosen, you can also use the V/F Curve to further offset the automatic voltage using Point Offsets.
    My exaplanation is not the best, you may want to check this amazing video below, and use it as a reference for underclocking / undervolting instead of overclocking.
    Video: https://www.youtube.com/watch?v=uNVPBH0bgQU
    Super Moderator Array
    Jul 2011
    95
    768
    Quote Originally Posted by berglake View Post
    Is it possible?
    the most direct way is to enter v/f point offset menu,
    start with -0.05v for the high frequency points vfpt8/7/6/5
