[G751JL] External Microphone Problems
iamfreeway
Hello! So I recently got these new pair of headsets and an audio splitter (since my ROG has a dedicated input for mics) and the mic is not working. I tried the headset on different devices and it works fine. However, it's just not working on my laptop. Is it a hardware problem? Is it a software/driver problem?
I apologize if this may not be the right forum to ask. Thanks in advance.
Blake1
Hi there,
do you have another mic or headset that you can plug in to G751JL?
or another audio splitter?
And does the built-in mic work?
Than it would be much clearer to see which one is the root cause.
