Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    ROG Member Array
    Mar 2021
    11
    choosing a x299 motherboard
    it seems like there is a lot of compromised or perhaps compromises... here is what I am looking for
    1) resizable BAR support (just got ASUS RTX3070 EKWB)
    2) 10th gen 48lane support, as far as I understand 10th gen is required for BAR support
    3) support at least one U.2 drive
    4) supports one 22110 lenght m.2, ideally a 2nd 2280 for optane
    5) has atleast one active/available pcie 1x for SCSI card
    6) one 8x slot for SAS raid array card
    7) 2 addtional 1x PCIe slots for parallel/serial IO and firewire card....
    8) not have my graphics card dropped down to 8x because for some stupid reason it has to share any bandwidth it drops down.
    Eveythinything I have looked at so far has had some level of compromize....
    right now I am on a rox strix x99
    so since the u.2 and m.2 slot share band with I have my u.2 ssd on a add on board
    my x99 would proably still give me eveything (excluding BAR even thought in theory ASUS could added it they wanted) I would want if either the PCIe 1_1 slot didn't share with the wifi or I the m.2/u.2 drive didn't share bandwidth.
    It seems like the x299 series doesn't get as much love as other platforms
    ROG Guru: Orange Belt Array G75rog PC Specs
    G75rog PC Specs
    MotherboardR VI Apex
    ProcessorI9-7900X
    Memory (part number)64GB Gskill Trident Z
    Graphics Card #1AMD Radeon VII EKWB water block
    Graphics Card #2Waste of PCI lanes in NVME environment
    Sound CardStock
    MonitorLG 34" Ultra Wide3440x1440
    Storage #14ea 960 Pro 2TB, 2ea 970 Evo 2TB
    Storage #21ea 960 Pro 1 TB, 1ea 970 Pro 1TB
    CPU CoolerEKWB CPU, Swiftech Res/pump, 400mm Rad
    CaseThermaltake View 91
    Power SupplyNZXT Hale 90 1200W
    Keyboard Logitech G910
    Mouse Razer Ouroboros
    OS W10 64 1809, 1903, Ubuntu Linux
    Network RouterNetgear R9000 + 4ea R9000 AP's, 10 Gb Switch
    Accessory #1 Hyper M.2 X16 V2
    Accessory #2 10GB network via Intel 550 Nic
    Accessory #3 2 10GB Asustor NAS 7000 series
    Jan 2013
    13
    306
    My Rampage VI X299 7900X Apex has no use for BAR since it has 64GB RAM and a Radeon VII with 16GB. Wifi, BT, Onboard NIC is disabled.
    With a Hyper X16 card I run 8 1&2 TB PCIe 3/4 NVME drives along with a mapped 34TB NAS on a 10Gb network with 1GB transfer rate doing away with the need for onboard Raid and slow SCSI/Sata/U2 drives. 4 of the onboard NVME's sport 4 different OS's to play with. Still has room for I/O cards.
    I wrote drivers to use nonstandard SCSI's for my Macs and started using them with my 386. When SSD's hit the market I used protocol converters for SCSI and IDE interfaces.
    Sata was left behind with the Apex converted to all NVME. Fun ride.
    Waiting for the next PCIe 4 or 5 board to come along.
    ROG Member Array
    Mar 2021
    11
    Quote Originally Posted by G75rog View Post
    I defiantly need to retain my legacy support my 3.84tb u.2 nvme is slightly faster than my windows boot 2tb m.2 NVME. I have linux running on a 2tb SATA SSD. I may a somepoint sun down the the SAS card and I had all my SAS SSD fail at once except for one 3.84TB drive. I did have all my games on my SAS raid array.... faster the SATA SSD array I was using but a single NVME is still fast. I can't fit my whole came library on a single 4TB SSD, I have have a 12tb and 16tb physical drives. Physical drive maybe slow but they are muhc more reliable for backup. In linux the disk overhead is so much less using SATA SSD doesn't feel as much like a performance hit. I was most thinking of using optane for it caching. I have an old fusion-io drive but didn't think it would be worth the lane usage. I could probably also loose the parallel and firewire as the USB-> parallel in theory should work well enough for my existing programmers..... USB to SCSI adapter don't work in windows and they are super slow and not super reliable.
    In the future if the motherboard support bifabrication , there are m2 format adapters that a relatively cheap. u.2 drives still seem slightly cheaper, faster, cooler and more reliable than their m.2 counterparts. I do have a two-port u.2 card but my existing motherboard doesn't support it.
    I do work on machine, retro stuff and play games..... it's an all-arounder. I feel like the industry forgets about industry and professionals a lot in the how me need legacy compatibility.
    ROG Guru: Green Belt Array restsugavan PC Specs
    MotherboardRAMPAGE VI EXTREME BIOS 3403 MOD
    ProcessorIntel Core i9 7980XE 2.60GHz
    Memory (part number)64GB GSKILL 3.2 GHz 16-16-18-36 2T
    Graphics Card #1ASUS ROG POSEIDON 1080Ti
    MonitorSAMSUNG ODESSEY G9 49 Firmware 1012.1
    Storage #1SAMSUNG 970 EVO PLUS 1TB x 3
    Storage #2WD 4TB External HDD
    CPU CoolerNZXT KRAKEN 62
    CaseCorsair Carbine 540
    Power SupplyCorsair AX1200i
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Headset/Speakers Sony
    OS Windows 11 Insider Preview 22000.100
    Network RouterD-LINK
    restsugavan's Avatar
    Sep 2017
    87
    685
    Lightbulb BEST X299 Mobo you must have
    Running Smooth after 3 Years passed
    Everything perfectly on this mother board
    except this one below
    https://rog.asus.com/forum/showthread.php?120609-OMG-WHO-DESIGN-ROG-RAMPAGE-VI-EXTREME-CMOS-Battery-placement!
    Windows 11 Build 22000.100 Core i9 7980XE 02006B06 MCU 2021-03-08 R6E 3403 BIOS TPM 2.0 Enabled VROC 7.5.0.1150+RST 18.31.1.5256 ME FW 11.12.86.1877 DV 2108.100.0.1053 64GB DDR4 3200 POSEIDON 1080i GTX NVIDIA Driver 471.41 WHQL 3TB SAMSUNG 970 EVO PLUS OMS Driver 18.34.0.1000 WHQL+i219 V OROM 0.1.00 BA 0.1.16 12.19.1.37 WHQL AQC 107n FW 3.1.121 AQC 2.2.3.0 WHQL CAM 4.25.0 Realtek HD 6.0.9161.1 WHQL SAMSUNG ODYSSEY G9 49 FW 1012.1 Windows 11 HDR1400 Certified
    Feb 2019
    91
    459
    Quote Originally Posted by restsugavan View Post
    Good luck with finding one of those. Ive seen a few used ones pop up here and there that are priced too high and you dont know what you are getting off of fleabay or how much of what came with it is missing.
    My recommendation for the OP would be the R6EE. Just bite the bullet and get it over. Best X299 on the market. Meets all your needs with an outstanding power delivery. The original R6E is OK if you can find one but the power delivery is 8 stages vs 16 of the newer boards. The VRMs would get hot with the stock cooler. Heat Killer does have waterblocks for the VRMs on that board though. You getr get more M.2 slots with the R6EE.
    ROG Member Array
    Aug 2018
    23
    The worst thing about Rampage VI Extreme is VRM cooling, specially with 10+ cores CPU (HOT)
    As You said, the best choice is Extreme Encore or Omega.
  7. #7
    ROG Enthusiast Array PanosXidis24 PC Specs
    MotherboardAsus Rampage V X99
    ProcessorIntel Extreme i7 6950X
    Memory (part number)CMK32GX4M4A2666C15
    Graphics Card #1Zotac AMP Extreme 980Ti SLI
    Graphics Card #2Zotac AMP Extreme 980Ti SLI
    MonitorQnix QX 2710 O.C
    Storage #1Corsair MP500
    Storage #2RAID 0 disk drivers
    CPU CoolerArtic Freezer 360
    CaseCooler Master HAF-X
    Power SupplyThermaltake Grand Touchpower 1050w
    Mouse Zowie EC2-A
    Headset/Speakers Razer Kraken 7.1 V2
    OS windows 10
    PanosXidis24's Avatar
    Jun 2018
    30
    Hot???mine no goes to 58c
  8. #8
    ROG Member Array
    Oct 2019
    20
    You might also consider the ASUS Prime X299 Edition 30 for a smaller form factor. It has a pretty decent VRM solution (better than vanilla R6E, similar to R6EO) and supports 48 PCIe lanes (distributed among PCIe slots and M.2 slots). You might need some U.2 adapter though.
  9. #9
    ROG Member Array
    Mar 2021
    11
    With the Rampage VI extreme the primary m.2 shares with the U.2 drive, so my 22110 m.2 would have to go in that funky DIMM slot. These sure look pretty in the promo but I feel like a lot of the flair would go unseen as it would be obstructed by the rear fan and radiator. The extreme version, like you mention I would need to I would need to go with an addon card for my u.2 drive and my main windows boot drive would need to go up into that DIMM slot and the onboard slot are max 2280.
    I do have some addition m.2 drives unused at the moment, I have the old 256gb drive from when upgrade my wife's computer and yet to be use 16gb optane drive. Previous I have purchased also a 1tb and 2tb NVME for two other things but it could probably repurpose one or the other. The 1tb drive I had bought for my Atari VCS but the final release version only support SATA m.2 drives, the 2TB drive I had purchased for the polymega but I am seriously beginning to down if that thing will ever be released
  10. #10
    ROG Member Array
    Mar 2021
    11
    Quote Originally Posted by BenJW View Post
    Looking at the prime that may work better, heat might be a thing. The 3070 generates way more heat than my previous cards when playing cyberpunk. I actually just finished the game last night and I could feel the heat coming out the the top. The GeForce auto optimize put the the game on lucrious/pysco setting.... I noticed the ray tracing a bit with the 2070 but it seemed kind no were near like results playing control.... Playing those setting seeming all the puddle reflections and stuff ingame was a little trip. The prime might be a better fit than the rampage VI extreme, the color scheme work clash a bit as eveything right now in my set up is orange and black.
