Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    ROG Guru: Yellow Belt Array Zeroed85 PC Specs
    Zeroed85 PC Specs
    MotherboardAsus Maximus XIII Hero - Z590
    ProcessorIntel i9 10900K - custom cooled
    Memory (part number)Dominator Platinum RGB 32GB 3866Mhz tuned
    Graphics Card #1ROG Strix 3080 OC - watercooled
    Sound CardSoundBlaster X AE-5
    MonitorAsus ROG PG349Q 34" 3440x1440 120hz G-Sync
    Storage #1Samsung 980 Pro 500GB, 860 Evo x 2,
    Storage #2Adata SX8200 Pro 1TB
    CPU CoolerCustom loop, EK PE 360, Corsair XR5 280 rads
    CasePhanteks Eclipse P600S
    Power SupplySeasonic Prime Ultra Platinum 1300W
    Keyboard Corsair K70 MK.2 SE
    Mouse Corsair Dark Core Pro wireless
    Headset Hifiman HE400i
    OS Win 11
    Accessory #1 Corsair Nexus
    Jun 2017
    207
    Exclamation XIII Hero - PCIE16_1 in 8x
    My GPU in the PCIE16_1 slot is running at 8x. I thought perhaps my PCIE 1x sound card occupying PCIE16_2 was causing this but after removing the sound card the PCIE16_1 slot is still in 8x. I have just one NVMe occupying the M.2_4 slot but no where in the manual does it say M.2_4 will share bandwidth with the PCIE16_1 slot.
    Can someone from Asus clarify? Why is my PCIE16_1 slot in 8x with just one NVMe plugged in? Please note I am using a 10th gen 10900K but the manual clearly states that 10th gen will run the PCIE16_1 slot in 16x mode.
    Zeroed85 PC Specs
    OS Win 11
    Jun 2017
    207
    Taken from the manual it clearly says M.2_2 shares bandwidth with PCIE16_1 and PCIE16_1 will run at 8x when M.2_2 is occupied. Nowhere does it say M.2_3/M.2_4 share bandwidth with PCIE16_1.
    So if I have just one NVMe occupying M.2_4 why is PCIE16_1 still in 8x and not 16x?
    ROG Guru: Orange Belt Array Saltgrass PC Specs
    Saltgrass PC Specs
    MotherboardMaximus XIII Hero
    Processori9 11900K
    Graphics Card #1EVGA RTX 3090 FTW
    Sound CardOn Board
    MonitorDell AW3420DW
    Storage #1Samsung 980 Pro 2 TB
    Storage #2Samsung 860 Pro 1 TB
    CPU CoolerCooler Master Hyper 212X
    CaseCooler Master
    Power SupplyAntec HCP Platinum 1000
    Keyboard ASUS Strix Flare
    Mouse ASUS Chakram
    Headset/Speakers Logitech wired 5.1
    OS Win 10 Pro
    Network RouterROG Rapture GT-AX11000/AXE11000
    Accessory #1 VR Headset
    Accessory #2 Saitek X52
    Jan 2014
    18
    421
    Your system specs seem to be a little out of date, so what processor are you running.
    The attachment is saying something a little different. It says when the M.2_2 slot is Enabled then PCIe16_1 will run at 8x. It does not say occupied..so is there a way to disable the M.2_2 slot?
    I will check mine with the 11th Gen processor..
    Zeroed85 PC Specs
    OS Win 11
    Jun 2017
    207
    Quote Originally Posted by Saltgrass View Post
    Sorry I just got this new hardware up and running so haven't changed any system specs yet. I did mention above I'm using a 10900K with the XIII Hero.
    Well you could just be right, enabled/occupied are different things. I will have to check the BIOS. Please tell me your result...
    Saltgrass PC Specs
    Processori9 11900K
    Sound CardOn Board
    CaseCooler Master
    Mouse ASUS Chakram
    OS Win 10 Pro
    Jan 2014
    18
    421
    My system is showing x16 on the slot and I have M.2_1 occupied..
    I did not see a setting in the Bios to disable the slot but some other setting (or Processor) might effectively do that.
    When I was running the 11th Gen on the XII, the PCIe16_1 slot was running at x8. Someone else mentioned they saw that was being done when running PCIe 4..
    Zeroed85 PC Specs
    OS Win 11
    Jun 2017
    207
    So what do you think the problem is? The screenshot below is about the most I could find related to PCIE and M.2. I would assume by using option 1 the M.2_2 slot should be disabled. Perhaps it is but PCIE16_1 is still in 8x.
Name:	PCIE M.2 config.png
  7. #7
    Saltgrass PC Specs
    Processori9 11900K
    Sound CardOn Board
    CaseCooler Master
    Mouse ASUS Chakram
    OS Win 10 Pro
    Jan 2014
    18
    421
    My guess would be the processor. I never ran the 10th Gen on this board so I cannot verify it does what you are seeing.
    The M.2_1 and M.2_2 slots both come off the processor with the M.2_1 being disabled with the 10th Gen. .. so it could be processor related..
    And there usually aren't any Official ASUS technical folks in these forums.
  8. #8
    Zeroed85 PC Specs
    OS Win 11
    Jun 2017
    207
    The manual clearly states 10th gen processors support PCIE 16. I guess I will need to create a support ticket if no one official can answer here.
Name:	Exp slots.png
  9. #9
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    178
    2,291
    Quote Originally Posted by Zeroed85 View Post
    Have you tried removing all expansion cards and NVME drives from the system and checking then?
    Might want to try both reseating the CPU and GPU to ensure proper contact.
  10. #10
    Zeroed85 PC Specs
    OS Win 11
    Jun 2017
    207
    Quote Originally Posted by Silent Scone@ROG View Post
    Last post I told a lie, I moved the sound card from PCIE16_2 to PCIE16_3. I removed the sound card completely this afternoon and PCIE16_1 is now reporting running in 16x mode. However I am stuck with a bit of a problem, the XIII Hero only has one 1x slot that I cannot put the sound card into because my GPU obstructs it. My question is why does the PCIE16_3 slot when populated with the PCIe 1x sound card drop the PCIE16_1 slot into 8x? The manual doesn't state anywhere that PCIE16_3 shares bandwidth with PCIE16_1.
