Results 1 to 8 of 8
    New ROGer Array
    Apr 2021
    4
    RTX 30 Series Cards - Corsair ICUE Plugin broken
    hey guys!
    since the last Bios update of my ROG STRIX RTX 3070 OC i can't control my graphics card in Corsair ICUE anymore.
    Since the update i can select 10 individual LEDs in ICUE (before the whole card showed up as 1 LED) but when i select every single LED only the right side of the Graphicscard RGB lights up and the rest bugs out and stays black.
    I noticed multiple people on the internet having the problem.
    -> https://www.reddit.com/r/ASUS/commen...icue_software/
    -> https://www.reddit.com/r/ASUS/commen...trip_shows_up/
    All claiming that it worked fine before the update. Maybe one of you has a fix or it can be passed trough to the development team.
    Im happy for any help!
    ROG Guru: Green Belt Array
    Feb 2019
    128
    597
    Did you save the previous BIOS? if so flash it back.
    New ROGer Array
    Apr 2021
    4
    No sadly not.
    Also at the moment of the Update trough armory crate i did not look closely if there was a update other than the BIOS update.
    I expect its not primarily the bios itself but the updated Asus ICUE Plugin. ICUE tells me the Plugin is updated to Version 1.2.2.0
    Really dont know what to do anymore
    ROG Member Array Minh Le PC Specs
    Minh Le PC Specs
    Laptop (Model)ROG Strix GL753VE
    MotherboardROG Z490 - E Gaming
    ProcessorIntel Core I7 10700KA
    Memory (part number)CMW16GX4M2E3200C16
    Graphics Card #1ROG Strix RTX 3080 O10G - Gaming
    MonitorLG 27GL850-B.ATV
    Storage #1WDS250G3X0C
    Storage #2Exceria LTC10Z240GG8
    CPU CoolerCorsair iCUE H115i RGB PRO XT
    CaseCorsair iCUE 465X RGB
    Power SupplyROG THOR 850W
    Keyboard Razer BlackWidow Chroma V2
    Mouse Razer DeathAdder Elite
    Headset Razer Kraken 7.1 Chroma V2
    Mouse Pad Razer Firefly Cloth Edition
    Headset/Speakers Logitech Z313 2.1
    OS Windows 10 21H1 build 19043.1052
    Oct 2020
    21
    17
    Unhappy
    Same here. Wait for new updates
    ROG Guru: Orange Belt Array HK-47's Avatar
    Feb 2012
    25
    318
    Have you tried Jacknet rgb synchronization software? I used it awhile ago before I put a waterblock on my gpu.
    https://rgbsync.com/
    -Desktop-
    Asus Crosshair VIII Dark Hero / AMD 5800x / 32GB Corsair Dominator Platinum RBG (CMT32GX4M4C3600C18) @ 3800 /2x Sabrent 1TB Rocket NVMe 4.0 (Raid 0)/ 1x Samsung 860 Evo SSD / Corsair AX1200 PSU / ASUS Strix Helios Case / Corsair HydroX Custom Loop D5, CX7, XG7 420+280 Rad/ Asus Strix 3090 / Asus PG35VQ Ultrawide Monitor / Corsair Commander PRO 3x ql120, 4x ql140 fans / Edifier 1850DB Speakers + T5 Sub /
    Asus Theta 7.1 Headset
    New ROGer Array
    Apr 2021
    4
    Had a look on it. Looks great but sadly ASUS RTX 30 Series cards are not yet supported in JacknetRGB.
    Maybe at some Point, but im gonna try it out on my girlfriends PC she is only using LL120's, Light Strips and a ROG Strix 1060.
    Should be working on her PC
  7. #7
    New ROGer Array
    Feb 2021
    1
    Bumping this because it's absurd for this to still be broken two months later. I specifically bought ASUS products with my Corsair stuff because of the RGB compatibility. In January/February the motherboard RGB control was broken and remained that way for about two months and then a month later someone breaks the RGB on current flagship cards and we have to wait two months with no fix and no way to roll back.
  8. #8
    New ROGer Array
    Apr 2021
    4
    jeah i also cannot understand that. Buying a product for much money and no one cares after getting your money.
    people at reddit and corsair forums are also enraged after this time. Still no one cares
Tags for this Thread
