Results 1 to 3 of 3
    New ROGer Array
    Apr 2021
    1
    Question Motherboard swap between Asus GL702VM and GL702VSK?
    Hi there,
    So recently I blow up my Asus GL702VM motherboard while I was changing the battery thanks to that little metal clip which holds the battery plug. So I was wondering whether I can swap the gl702vm with gl702vsk motherboard(i7-7700hq,1070)? Because what I saw in pictures both motherboards are identical except for heat sinks. Which only covers the 2 extra black chips on gl702vsk while gl702vm has a small fan at that place which can easily fit over those 2 chips . Is there any other risk in that? Both motherboards pictures are below.
    https://ibb.co/F5ZcHY8
    https://ibb.co/12tp7LB
    ROG Guru: Orange Belt Array raju2529 PC Specs
    raju2529 PC Specs
    Laptop (Model)R542UQ-DM153 ( X542UQ.309SA )
    MotherboardAsus Builtin Motherboard X542UQ
    ProcessorIntel core i5 7200u @2.5Ghz
    Memory (part number)Adata 2400 Mhz 16GB DDR4
    Graphics Card #1intel HD 620 graphics 1GB DDR3 DCH WHQL driver v.30.0.101.1121 Beta
    Graphics Card #2Nvidia GeForce 940MX 2GB GDDR5 DCH WHQL driver v30.0.14.9676
    Graphics Card #3nil
    Graphics Card #4nil
    Sound CardRealtek HD Audio controller with codec ALC294 WHQL driver v10.0.22000
    MonitorBuiltin Lcd monitor model BOE
    Storage #1Samsung 850 Evo 1000GB SSD M.2. 2280
    Storage #2Seagate 2TB 2.5inch 5400rpm and Seagate 2TB 2.5inch 5400rpm2.5 inch
    CPU CoolerBuilt-in
    CaseFrom factory
    Power Supply65W
    Keyboard Built in keyboard
    Mouse Built in mouse
    Headset Purchased Philips HeadSet
    Mouse Pad nil
    Headset/Speakers Realtek Builtin Speakers
    OS Windows 11 Enterprise 64bit v21H2 build no 22000.318
    Network RouterNextVision ONU Fiber Modem
    Accessory #1 Del Wired usb Mouse
    Accessory #2 Laptop Cooling table with fan
    Accessory #3 Secureye Usb finger print scanner added seperately for Windows Hello
    raju2529's Avatar
    Feb 2018
    9
    362
    hi Barefooted, your case is new . if you want to change motherboard you can go head , also change processor also that comes with new motherboard.
    also I ma doubt whether top cover is completely fit on laptop base cover or not.
    Moderator Array
    Feb 2019
    14
    852
    Hi Barefooted,
    We do not suggest to swap motherboard of different model.
Tags for this Thread
