Results 1 to 5 of 5
    ROG Enthusiast Array
    Jan 2015
    11
    51
    Balanced Power Plan freezing/crashing
    Hi i need help with my new setup.
    My computer will keep crashing when idling if i set my power plan in windows 10 to Balanced. PCI Express link state power management is off.
    It wont crash when im gaming or under heavy load.
    I can game for hours in balanced power plan. But once i quit the game and leave my computer idle for a few mins, it will just freeze or auto restart.
    Anyidea what causing this issue ??
    If i run my system in High Performance no crashing or freezing. But i dont want the core frequency and vcore to be lock at max.
    Z490 Igaming
    Intel i9-10900k
    Strix 3090 OC
    32GB Corsair ram
    750watt corsair PSU
    Jan 2015
    11
    51
    Up this, hope someone would be able to help me with this issue
    Moderator Array
    Feb 2019
    14
    773
    Hi there,
    Was there any error message ?
    You can trace back in event viewer or other log tool after the auto shutdown.
    What's your BIOS version and the game you are playing?
    ROG Guru: Orange Belt Array Jesseinsf PC Specs
    Jesseinsf PC Specs
    Laptop (Model)N/A
    MotherboardASUS ROG Maximus XI Extreme (Z390)
    ProcessorIntel Core i9 9900K
    Memory (part number)Corsair CMW128GX4M4E3200C16 - 128GB (4x32)
    Graphics Card #1NVIDIA - GeForce RTX 2080 Ti FE
    Sound CardOnboard TOSLINK to powered speakers
    MonitorMSI Creator PS321URV (32 in 4k HDR600)
    Storage #1Samsung 980 Pro M.2 PCIe SSD 1TB
    Storage #2Samsung 970 Pro M.2 PCIe SSD 1TB
    CPU CoolerLian Li Galahad 360 (3x Uni fan SL120)
    CaseLian Li PC-011 Dynamic XL Black (ROG Certified)
    Power SupplyCooler Master V1200 Platinum
    Keyboard RAZER HUNTSMAN ELITE - LINEAR OPTICAL SWITCH (Red) w/ PBT Keycaps
    Mouse Razer Basilisk Ultimate with Charging Dock
    Headset Bowers and Wilkins P9 Signature
    Mouse Pad LOFTMAT (16x13 inch) Cushioned Gaming Mat - "The Gaming Slim"
    Headset/Speakers Vanatoo Transparent One Encore with Rel HT/1003 Subwoofer
    OS Windows 11 Pro for Workstations 64-bit
    Network RouterROG Rapture GT-AC5300 (Using Spectrum 400MB service)
    Accessory #1 Microsoft Xbox Elite Wireless Controller Series 2
    Accessory #2 2x Logitech BRIO ULTRA HD PRO WEBCAM
    Accessory #3 7 Uni Fan SL120 fans for PC case
    Jesseinsf's Avatar
    Mar 2019
    45
    383
    Have to enabled power saving features in the BIOS. C-States need to be enabled and all the throttling CPU features need to be enabled. And turn on Link State Power Management to test.
    ROG Guru: White Belt Array RobertoSampaio PC Specs
    MotherboardMaximus XII Formula
    Processori9 - 10900KF - SP86 - 56x4 - 55x6 - 54x8 - 53x10
    Memory (part number)2X - KHX3733C19D4/16GX - 4100MHz
    Graphics Card #1Gigabyte RTX-3080 GAMING OC
    MonitorLG-34GL750 - 144Hz
    CPU CoolerCorsair H115i - Pro 280mm
    CaseCorsair Graphite Series 780T White Full-Tower
    Power SupplyCorsair HX 1000i - 1000W
    Keyboard Corsair k90 Vengeance
    Mouse Corsair Scimitar Elite
    OS Windows 10 Pro - 21H1
    Sep 2020
    85
    Crashing or freezing at idle is a symptom of low voltage at high frequencies ...
    Check and rise V/F #6,7 and 8, or increase adaptive voltage
