Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    ROG Member Array
    Sep 2018
    16
    Ryujin 360 Micro Fan Not Working
    Hello today I replaced my asus rog ryujin 360 cooler fans with corsair ll120 fans I was unable to control the micro fan via software after changing the fans. Is this normal?
    New ROGer Array
    Feb 2021
    1
    I have not replaced the fans and the microfan isnt working either, noticed it today by pure luck.
    Did a firmeware update and it spun up for while reinstalling version 0205.
    After the installation microfan returned to twitching, every 5 seconds or so.
    ROG Member Array
    Sep 2018
    16
    Quote Originally Posted by Vitriolic View Post
    When you unplug the USB cable, the micro fan starts running at top speed. I could not understand the reason for this
    ROG Guru: Brown Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardCrosshair VIII Dark Hero
    Processor5900X 4.6ghz All core 1.3V, 5ghz single DOC
    Memory (part number)Gskill NEO 3600 CAS 14 32GB (4x8)
    Graphics Card #1ROG Strix RTX 3080
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 980 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 980 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks 500A Mesh
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur Virtuoso
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    80
    1,003
    Have you installed Armory Crate and updated all the modules?
    With the USB connected to a MB header, and the pump connector attached to the AIO MB header, in Armory Crate under the Ryujin Device, the Radiator fans are controlled under 1 drop down setting (for both fans) and the Micro Fan under another drop down menu choice. Is this were you are trying to control from? The pump is controlled through the BIOS if you want it to run at anything less than 100%.
    Make sure your replacement radiator fans are 4 pin PWM fans.
    New ROGer Array Leeroy Rz PC Specs
    Leeroy Rz PC Specs
    Laptop (Model)-
    MotherboardROG MAXIMUS XI FORMULA
    Processori9 9900 KS
    Memory (part number)32 Go 3600 CAL 16
    Graphics Card #1ROG 3090 O24G
    Graphics Card #2-
    Graphics Card #3-
    Graphics Card #4-
    Sound Card-
    MonitorG9 Odyssey + G7 32 pouces
    Storage #1SSD 970 EVO Plus 500Go
    Storage #2SSD 860 EVO 1To + SSD 860 QVO 1To
    CPU CoolerRog Ryujin 360
    CaseRog Helios
    Power SupplyRog Thor 850w
    Keyboard Razer Hunstman v2 ANALOG + Hunstman elite
    Mouse RAZER BASILISK ULTIMATE
    Headset Razer Nari Ultimate
    Mouse Pad Razer Firefly hard edition
    Headset/Speakers Logitech stéréo
    OS W10 Pro
    Network Router-
    Accessory #1 Razer Tartarus V2
    Accessory #2 Rog Arion
    Accessory #3 -
    Dec 2019
    1
    Unhappy Ryujin 360 : micro fan down
    Me and my girlfriend also have a "Ryujin 360", and I also saw that the microphone fan was no longer running.
    This is for us because of an update of the software "Armoury Crate"
    Because that’s stopping suddenly, my WC is not even 1 years old, and my girlfriend’s under 6 months old.
    I just reinstalled windows properly..
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    28
    1,852
    The rerport was send the day of AC version 4 was deploy
    We wait
    I have test all scenarios possible. Will not work. I send the report day 1
    Learn, Play Enjoy!
  7. #7
    mdzcpa PC Specs
    Sound CardOn Board
    MonitorROG PG348Q
    OS WIN 10 Pro
    Nov 2011
    80
    1,003
    Â* I haven’t noticed my micro fan not working and I have all the AC updates too. I will double check my own rig later tonight.
    Have you tried a custom speed setting? Â*I run my own fan curve on that fan. The drop down menu choice is still there?Â*
  8. #8
    ROG Member Array
    Sep 2018
    16
    Quote Originally Posted by mdzcpa View Post
    Nothing changes when I make changes micro fan speed via armory crate
  9. #9
    MrAgapiGC PC Specs
    Processor9900K
    CaseNzxt H700
    Mouse Asus Spartha
    MrAgapiGC's Avatar
    Nov 2011
    28
    1,852
    Update has being push now. Please check.
    I run a small test and the update put the mini fan to work again.
    I will make some checkup and report back later But the update fix it.
    If update arrive installed it and restart the pc. but it works now perfect
Name:	Screenshot 2021-04-20 082734.png
    Learn, Play Enjoy!
  10. #10
    ROG Member Array
    Sep 2018
    16
    Quote Originally Posted by MrAgapiGC View Post
    fixed after update thank you
