Results 1 to 6 of 6
    New ROGer Array
    Apr 2021
    4
    Armoury Crate problems
    Hi, i'm new in this forum and have some trubleshotings on that windows app.
    My actual config is Asus Rog Strix e-gaming 3603 bios
    AMD 3900X CPU
    Asus Rog Strix RTX 2070 O.C.
    16 gb G.Skill Trident DDR4 F4 3600C16
    SSD Sabrent Rocket Plis 1Tb NVme.
    Windows 10 Pro 20H2
    Before this i had old P8 Z77- v deluxe wifi and i used as software AISUITE 2.0.
    When i have installed New Rog Strix i forgot to uninstall AIsuite and installed ArmouryCrate..
    ArmouryCrate recognize correctly Aurasync but when i go
    in programs to install there is possibility to download AiSuite 3.0 but i have seen on some video that i should control all functions about motherboard like fan and O.C parameters through Armourycrate and not trough AiSuite.
    I also can see in bios i just find old bios and not new ones
    I tried to reinstall just ArmouryCrate and not AiSuite also with cleaner programs and manualy delete keys from windows
    Ialso can't connect ArmouryCrate with iPhone App
    Can someone give me some advices not forcing me to reinstall Windows 10?
    ROG Enthusiast Array flagrant99 PC Specs
    flagrant99 PC Specs
    MotherboardASUS ROG Strix B550-I Mii ITX
    ProcessorRyzen 7 5800X
    Memory (part number)F4-3200C16-16GTRS
    Graphics Card #1XFX Radeon RX 570 4GB
    Sound CardSupremeFX7.1 Surround Sound High Definition Audio CODEC S1220A
    Storage #1Samsung - 980 PRO 1TB PCIE 4.0 x4 NVMe Gen4 SSD M.2
    CPU CoolerASUS ROG Ryuo 120
    CaseThermaltake Tower 100 Snow Edition
    Power SupplyCORSAIR - RMx Series 850W
    OS Windows 10
    Apr 2021
    29
    Armoury Crate Uninstall Tool
    Do not uninstall anything directly. Makes a mess. Use the Armoury Crate Uninstall Tool.
    ROG Member Array MJr418 PC Specs
    MJr418 PC Specs
    MotherboardPrime x570-p
    ProcessorAMD Ryzen 5 3600
    Memory (part number)4 x 8gb Vengeance pro RGB
    Graphics Card #1MSI GTX 970
    MonitorDual LG 24"
    Storage #1Samsung 850 Evo
    Storage #2Samsung 860 Evo
    CPU CoolerCM 212 Hyper BE RGB
    Casenot branded case
    Power SupplyThermaltake Toughpower
    Keyboard Logitech G815
    Mouse Logitech G600
    Headset Logitech G pro
    Headset/Speakers Logitech Stereo Speakers
    OS Windows 10 pro
    Accessory #1 aRGB Fans
    Accessory #2 aRGB Strip
    Oct 2020
    18
    Quote Originally Posted by leone101 View Post
    AMD 3900X CPU
    Windows 10 Pro 20H2
    Armoury crate you saw was in laptops not Desktop, Desktop use AIsuite, Armoury Crate in desktop control lights and some updates no fans there.
    New ROGer Array
    Apr 2021
    4
    Quote Originally Posted by MJr418 View Post
    Thanks for your answer! infact i had some dubts..... but i thought it would be nice if i needed just All in One program to control System.
    I also really can't understand why program don't give me right bios version to be downloaded
    New ROGer Array
    Apr 2021
    4
    Quote Originally Posted by flagrant99 View Post
    Yes sure i used that! Thanks
    and i used also install tool from asus product support page
    MJr418 PC Specs
    MonitorDual LG 24"
    Mouse Logitech G600
    OS Windows 10 pro
    Oct 2020
    18
    Don't really know, Like Aura creator and Armoury Crate why 2 instead of just 1 software, Asus Has good Hardware but Bad software so Do I recommend anyone to buy any of Asus product >> NO << you can't Drive 1000hp Car with bad tune.
