Results 1 to 2 of 2
    New ROGer Array
    Jan 2020
    2
    Unhappy REQ: vBIOS for RTX2080 max-q from rog zephyrus gx710 ?
    hi everyone,
    i was an idiot and flashed the vbios of Alienware a51m on my rog zephyrus gx701gxh (9750h) (as i wonder to try the higher voltage setup). both cards are rtx2080 max-q.
    now the gpu does not get detected regardless of how many times i try to reinstall the drivers: https://i.imgur.com/7eKUq1Y.png
    is there any way to fix this?
    Anyone can dump a vbios from the zephyrus gx701gxh ?
    i tried flashing this vbios https://www.techpowerup.com/vgabios/213643/213643 but the results are the same.
    thanks a lot in advance. at this point i don't know what else there is left to do.
    New ROGer Array
    Jan 2020
    2
    obviously theres a type in the title.
    It's GX701GX.
    Anyone with this laptop can dump a vbios from CPUZ please?
Tags for this Thread
