Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Enthusiast Array
    Dec 2011
    43
    Z590 Glacial - USB portís issue
    I seem to be having an issue with 3 x USB ports, they are simply not working... they did work intermittently when I first setup the mobo, but have since stopped.*
    Iím running a fresh install of windows with all the latest drivers/bios installed...
    I can live with the issue, but wondering if their is an obvious fix that I can apply/attempt...*
    All other ports are working perfectly..*
    Any troubleshooting steps would be appreciated *
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    199
    2,556
    Can you show which ports on the board don't appear to be working?
    Dec 2011
    43
    Itís the 4 that I have circled in red - the 2 by the HDMI port and the 2 by the lan ports
    Mar 2016
    199
    2,556
    Thanks for that.
    Can you give me your specification and upload a DXDIAG, please? (Type Dxdiag into Windows Search, open DXDIAG and click save information)
    Have you changed anything since the ports stopped working?
    What are you plugging into the rear I/O?
    What devices are you plugging into those ports specifically?
    Dec 2011
    43
    I haven't changed anything
    I have 4 x usb devices (see below) and a network cable plugged into the rear I/O
    I have 2 x fan/rgb controllers and 2 x usb hubs...
    DXDIAG - I cant seem to upload, keep getting an invalid file error...
    Mar 2016
    199
    2,556
    No worries, will pm.
  7. #7
    ROG Guru: Black Belt Array Hopper64 PC Specs
    Hopper64 PC Specs
    MotherboardAsus MZ690E Bios 1403
    Processori9 12900KS
    Memory (part number)GSkill F5-6000U3636E16GX2-TZ5RK
    Graphics Card #1Asus 3090 Strix OC/Optimus Block
    Sound CardCreative SB X4
    MonitorAsus ROG XG349C
    Storage #1Samsung 980 Pro
    CPU CoolerQuantum Kinetic TBE 300 D5 with Quantum VTX 160
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1600i
    Keyboard Asus ROG Claymore 2
    Mouse Asus ROG Gladius III
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    70
    2,396
    I’m having similar issues with my M13EG too. The USB ports seem to work intermittently. Same ones as outlined. I haven’t loaded windows on this build yet. Is there a fix for this? I even got a message on boot that the machine will shut down in 15 seconds due the usb overload. Just had connected 2 Samsung T5s via the USB C ports. Removed those an problem solved. Never had this issue with other boards, like my R6EE. Connecting them in different ports also seems to alleviate the problem too.
    I also question whether my problem is simply due to not having windows installed yet with the appropriate windows drivers. *
  8. #8
    Dec 2011
    43
    I haven’t resolved the issue yet.*
    Fresh install won’t fix it, I have done that twice and the problem persists…
    I have also never got a notification to suggest their is a USB overload…
  9. #9
    Hopper64 PC Specs
    Processori9 12900KS
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    70
    2,396
    I’m still tinkering with mine. I’ll report back if I figure something out.
  10. #10
    ROG Member Array
    Apr 2018
    18
    Quote Originally Posted by Silent Scone@ROG View Post
    Thanks for that.
    I dont have a Glacial but I do have the M13E and I am runnning into a similar issue.
    Fresh windows10 pro install
    11900K
    32GB Ram
    Samsung NVME
    if you connect more than 2 USB devices, the systems seems to hang. Its not hung up, its the usb stops working.
    I thought I figured it out, thinking it was my mouse, but then swapping to different mouse seemed to clear up the issue, but then it moved on to keyboard, then usb sound bar, than any other usb device.
    I am getting an error in device manager that says:
    Windows has stopped this device because it has reported problems. (Code 43)
    The USB hub failed to reset.
    Here is a link to my Google Drive for the text file:
    https://drive.google.com/file/d/1mZ9...ew?usp=sharing
