Results 1 to 6 of 6
    New ROGer Array
    Apr 2021
    3
    Exclamation G531GW Interference noise with any earbuds
    Hello everyone,
    I have a new ROG ASUS Notebook Rog Strix G531GW Monitor 15.6", from only like 6-7 months.
    I always had this problem with any earbuds that i have to connect with audio jack on the notebook: i hear this Interference noise that is very annoying. I tried to change airbuds but the problem remain, i dont know what to do.
    The notebook didnt take any damage, 0.
    Do you think that the sound card is faulty? Any headset usb or bluetooth that I use don't have problems, only the earbuds that I have to connect via the audio jack.
    Please help me.
    thank you
    ROG Guru: Black Belt Array toronto699 PC Specs
    toronto699 PC Specs
    Laptop (Model)G752-VY-DH78K , G751-JYDH72X
    MotherboardRog Tytan G30AB
    Processori7-4770K
    Memory (part number)32GB
    Graphics Card #1Asus Gold20th GTX980Ti
    Sound CardDell X-Fi Audigy SoundBlaster
    Monitor3 Acer K272HL
    Storage #1118 GB/OS
    Storage #22.72 TB
    CPU CoolerIntegrated Liquid-Cooled CPU
    CaseG30AB
    Power SupplyAsus 700 Watt
    Keyboard Razer BlackWidow Ultimate
    Mouse Razer Diamond Back
    Headset Sony Studio Professional , Razer Seiren Mic
    Mouse Pad Razer FireFly
    Headset/Speakers Logittech 5.1 Z-5500
    OS W 10
    Network RouterSagemon Fast 5250 Hub 2000
    Aug 2014
    96
    2,563
    What Audio Driver Do You Have ? It May Be A Driver Issue Check The Driver Version You Have
    https://www.asus.com/US/supportonly/...Desk_Download/
    https://www.asus.com/us/support/#!consumer/csn9
    New ROGer Array
    Apr 2021
    3
    Quote Originally Posted by toronto699 View Post
    i tried to uninstall my version and install the right version from the official asus site but nothing changed unfortunately
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    334
    7,937
    A hum can be due to a poor ground or minor short. Unless you can see the internals of the jack are bent it would probably require opening the machine to inspect for wiring faults.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    New ROGer Array
    Apr 2021
    3
    Quote Originally Posted by xeromist View Post
    yeah I can't see anything inside. Do you suggest me to open it? I dont know if is a good idea, for the warranty i mean.
    I open notebooks everyday because is my job, i work for it, but they are offices computer not gaming and i dont know if i'll open this the warranty will still be good or not.
    What do you suggest?
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    334
    7,937
    I can't really advise you on Italian/EU warranty limitations as I don't know. It would be good to read the warranty terms for your region. But if you are still under warranty then the best move would be to just create an RMA and let ASUS handle it.
    If you decide to check for yourself: My experience with headphone jacks is that they are often fully encased in a small plastic housing so you may not be able to see much if it has an internal fault. I would look for obvious issues like bad solder joints or anything bridging the connections that doesn't look like it should be there.
