Results 1 to 6 of 6
Thread: RGB Assistance
    New ROGer Array
    Feb 2021
    2
    RGB Assistance
    I am trying to wire 12 Deep Cool RGB fans, 3 Phanteks neon strips, and the cooler has rgb as well. I am using a Cooler Master hub for the rgb power and getting signal from the MB and running Armory Crate. It seems too much for the hub to handle and I have had to unplugs some rgb fans to make it work. Is there a hub that I can use that has a higher current rating for 5v addressable rgb??
    Any assistance is appreciated...
    ROG Enthusiast Array
    Apr 2021
    27
    Quote Originally Posted by Radio_Dude View Post
    You can use a hub for each ARGB port on your MoBo (If you have more than 1), or you can split one port with a argb splitter cable and use one hub for each terminal.
    New ROGer Array
    Feb 2021
    2
    Quote Originally Posted by Cheeseburger View Post
    I only have one header and I originally tried a splitter into two powered hubs and it did not want to work. When I first brought the system up it would not work at all. It then started to work when I unplugged one of the hubs. Now I just run three fans static in the top of the case but I really want them all to sync. This seemed to be a simple thing but I could really use some assistance now.
    Apr 2021
    27
    You can use one hub as slave of the other, this way should work with no problems.
    Apr 2021
    27
    Did it finally work?
    ROG Member Array
    Dec 2021
    15
    Are you on your working ways now?
