Results 1 to 4 of 4
    ROG Member Array
    Dec 2014
    23
    Fan step up/down not working?
    I have erratic fan speed ramp up, using the arctic liquid freezer ii 360.
    I've tried the fan step up/down function, but it doesn't seem to do anything? I've done the Q-Fan tuning, as well as tried multiple manual fan curves, but can't quite seem to get rid of the problem..
    Got the Asus Rog Strix Z590-F with latest bios 0708.
    ROG Guru: Orange Belt Array
    Feb 2019
    91
    465
    The ASUS fan control is something Ive never had luck with like ever. Thge exact same thing you are posting. Up and down and up and down and up and down, lather rinse repeat. I found my home with fan control using aqauero products. They work and you can set a profile with a very tight gap and it will ramp the fans where they need to be to stay in your profile.
    Moderator Array
    Feb 2019
    14
    715
    Hi Nitrius,
    Have you tried the Fan Xpert to adjust the fan?
    https://www.asus.com/support/FAQ/1034000/
    If there is any issue, please share some screenshot or video of the issue with us.
    ROG Member Array
    Dec 2014
    23
    Quote Originally Posted by Blake@ROG View Post
    Hi Nitrius,
    I gave it a try, but it seems to not detect my 3 chassis fans which are connected to the Nexus Hub on Fractal Meshify 2. So those fans just speeds on full, they are adjustable in bios but you don't see the fan speed of course.
    Is the detecting of fans between bios and fan expert different? I did run the fan tuning btw.
