Results 1 to 3 of 3
    ROG Member Array
    Mar 2021
    24
    To Flash or not to Flash
    Does it make difference when updating bios if I use AI Suite vs flash??
    Moderator Array
    Feb 2019
    14
    717
    Hi there,
    The process is different. But result is the same.
    Please refer to below link
    https://www.asus.com/support/FAQ/1012152/
    https://www.asus.com/support/FAQ/1012815/
    ROG Member Array
    Mar 2021
    24
    Thanks...
