Results 1 to 3 of 3
    ROG Member Array ZeroCool22 PC Specs
    ZeroCool22 PC Specs
    MotherboardASUS ROG STRIX B550-F GAMING (WIFI)
    ProcessorRYZEN 9 5900X
    Memory (part number)CORSAIR 2x16 3000 Mhz CMW32GX4M2C3000C15
    Graphics Card #1MSI GTX 1080TI 11GB GAMING X
    CPU CoolerCOOLER MASTER MASTERAIR MA610P RGB
    Power SupplyAEROCOOL KCAS 700WFULL RANGE
    OS Windows 10 x64
    Apr 2021
    7
    Exclamation SATA AHCI drivers problem? (AMD system)
    Motherboard:
    Processor:
    RYZEN 9 5900X
    Memory (part number):
    Graphics Card #1:
    CPU Cooler:
    Power Supply:
    OS:
    Windows 10 x64 (20H2)
    I should have the same amount of SATA drivers than HDD/SSD drives i have?
    I have 5 Disks installed in my system (3 SSD and 2 HDD) but i only have 1 SATA AHCI driver...
    Also it says it's from 2006...
    I feel my system a little sluggish in daily tasks jobs, could it be a problem of the SATA drivers?
    ROG Guru: Green Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD NVMe Samsung 970 EVO Plus 500GB
    Storage #2SSD NVMe Samsung 960 EVO 250GB | SSD NVMe Corsair Force MP510 240GB | SSHD AHCI Seagate FireCuda 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Headset/Speakers Logitech Z333
    OS Windows 11 64 bit 21H2/CO/22000.x
    MoKiChU's Avatar
    Aug 2013
    319
    572
    To understand better, you should know that :
    SATA AHCI : The controller is in your motherboard, and it drives all your SATA AHCI SSDs/SSHDs/HDDs connected on it (so there will be 1 single SATA AHCI Controller device for all SATA AHCI SSDs/SSHDs/HDDs).
    PCIe NVMe : The controller is in your NVMe SSDs (so there will be as many NVMe Controller devices as there are NVMe SSDs).
    So to summarize, yes it's normal.
    ZeroCool22 PC Specs
    OS Windows 10 x64
    Apr 2021
    7
    Quote Originally Posted by MoKiChU View Post
Tags for this Thread
