Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Member Array
    May 2021
    7
    Wake on LAN Bios Setting
    I have a ROG STRIX Z490-I GAMING and I want to use Wake on LAN.
    There does not seem to be a relevant setting anywhere in the bios.
    Please can someone point me in the right direction?
    Thanks in advance
    ROG Guru: Green Belt Array Saltgrass PC Specs
    Saltgrass PC Specs
    MotherboardMaximus XIII Hero
    Processori9 11900K
    Graphics Card #1EVGA RTX 3090 FTW
    Sound CardOn Board
    MonitorDell AW3420DW
    Storage #1Samsung 980 Pro 2 TB
    Storage #2Samsung 860 Pro 1 TB
    CPU CoolerCooler Master Hyper 212X
    CaseCooler Master
    Power SupplyAntec HCP Platinum 1000
    Keyboard ASUS Strix Flare
    Mouse ASUS Chakram
    Headset/Speakers Logitech wired 5.1
    OS Win 10 Pro
    Network RouterROG Rapture GT-AX11000/AXE11000
    Accessory #1 VR Headset
    Accessory #2 Saitek X52
    Jan 2014
    18
    619
    It is normally in the Device Manager Properties for the device and a Power Management tab..
    ROG Member Array
    May 2021
    7
    I have enabled that already. I believe it needs to be specifically turned on in the BIOS but cant find the relevant setting. Any pointers to whether this MoBo supports it and/or where to find BIOS settings would most appreciated.
    ROG Guru: Yellow Belt Array
    Dec 2013
    19
    195
    I think it is under Advanced tab, Network Stack.
    Also at the top of the bios there is a search tab in most bios now days.
    ROG Member Array
    May 2021
    7
    Thanks, I will have another look in the BIOS when I am at the PC next week. Software side setting shared below:
Name:	Screenshot 2021-05-14 171332.jpg
Name:	Screenshot 2021-05-14 171357.jpg
Name:	Screenshot 2021-05-14 171414.jpg
    ROG Member Array
    May 2021
    7
    Sadly I cant find it under network stack or anywhere else. Is wake on lan always supported or is there a chance this MoBo does not have that feature?
  7. #7
    Dec 2013
    19
    195
    Maybe try this https://youtu.be/MCizY0Iw8xY I have never used Wake On Lan so I am not sure.
  8. #8
    Saltgrass PC Specs
    Processori9 11900K
    Sound CardOn Board
    CaseCooler Master
    Mouse ASUS Chakram
    OS Win 10 Pro
    Jan 2014
    18
    619
    Quote Originally Posted by edcoppen View Post
    Can I ask why you show to only allow a Magic Packet to wake the system? If you wanted to test if it wakes, uncheck that to see if it does.. If it does wake up, the command below should tell you what woke it..
    powercfg /lastwake
  9. #9
    ROG Member Array
    May 2021
    7
    Quote Originally Posted by bscool View Post
    Unfortunately I seem to have a different bios without that layout/option.
  10. #10
    ROG Member Array
    May 2021
    7
    Quote Originally Posted by Saltgrass View Post
    powercfg /lastwake
    So I have two computers on the same network. One is always turned on, while the second is usually off. I want to use the first PC to turn the 2nd one occasionally. I know logmein supposedly supports this and they say to enable that setting here.
    I guess I dont have to use logmein. Is there another program I could use to test this?
