Results 1 to 5 of 5
Thread: Internal USB Splitter/HUB?
05-16-2021 03:09 AM #1
Nonny PC Specs Motherboard Rampage VI Extrem ENCORE Bios:1004 Processor intel i9-10900x Memory (part number) Corsair CMK32GX4M4A2666C16 (64 GB) Graphics Card #1 Asus GTX 1060 6 GB Sound Card Creative ZxR Monitor Samsung Ultrawide 34" + Asus MX279 27" Storage #1 Samsung SSD EVO 500 GB Storage #2 Samsung ST2000DM01 CPU Cooler Corsair Hydro Series H150i 360mm Liquid CPU Cooler Case 011 Dynamic XL black Power Supply CoolerMaster Silend Pro 850W Keyboard Asus ROG Claymore Mouse Logitech MX Master 3 + ROG Spatha (gaming) Headset Razer Tiamant 7.1 Analog Mouse Pad ROCCAT Hiro Headset/Speakers F&D No.: 6000U OS Windows 10 x64 Network Router TP-Link Archer AC8 Accessory #1 3D Conexion - 3d Space mouse Eterprice Edition Accessory #2 Wacom Intuos 5m Pro Wireless Accessory #3 Logitech BRIO
- Join Date
- Mar 2015
- Reputation
- 19
- Posts
- 106
Hello @ All,
here another "strnage" question : the R6E Encore has only 1 USB 2.0 internal connector so i had to sacrifice one USB 3.0 Tower Connector and plug the Delivered USB 3.0 --> USB 2.0 Adapter cable in , then i was thinking i could mabe "split" the USB with an internal HUB like the one from NZXT Internal USB splitter zu use my external USB tower ports AND the RGB corsair light node and i allready have a AIO Capellix 360 in the tower , and here it comes the nice magnetic looking NZXT is in the reviews not that well :
I read :
- Blow up
- Smoke comes out
- Damaged the USB connector on the MB
- Cover dropped dow becouse cheap made
- Molex connector (old Technices)
- worked only for short time then damaged
- Extra power cable was melting ..
ok ok , that looks not that good to me , here my question :
Is it recommendable to use a splitter and what would be a good solution for this ? What splitter is save to use ? i ask for some experience because i dont know now what to do or maybe better i dont do it ...
My Idea is the following: I want to connect AIO Corsair Capellix (Commander core USB 2.0), and a Lighting NODE core for the RGB fans extenson (USB 2.0) AND my USB 3.0 Tower Ports (without the Delivered 3.0 to 2.0 Adapter cable , then i would have to "Split" the USB connector into 2 connectors but the internal NZXT made mi fear to damage the system
Thanks for ANY help and yor time Reading my Question
With friendly Greetings
NonnyLast edited by Nonny; 05-16-2021 at 03:12 AM. Reason: why not ;)
05-16-2021 03:50 AM #2
G75rog PC Specs Motherboard R VI Apex Processor I9-7900X Memory (part number) 64GB Gskill Trident Z Graphics Card #1 AMD Radeon VII EKWB water block Graphics Card #2 Waste of PCI lanes in NVME environment Sound Card Stock Monitor LG 34" Ultra Wide3440x1440 Storage #1 4ea 960 Pro 2TB, 2ea 970 Evo 2TB Storage #2 1ea 960 Pro 1 TB, 1ea 970 Pro 1TB CPU Cooler EKWB CPU, Swiftech Res/pump, 400mm Rad Case Thermaltake View 91 Power Supply NZXT Hale 90 1200W Keyboard Logitech G910 Mouse Razer Ouroboros OS W10 64 1809, 1903, Ubuntu Linux Network Router Netgear R9000 + 4ea R9000 AP's, 10 Gb Switch Accessory #1 Hyper M.2 X16 V2 Accessory #2 10GB network via Intel 550 Nic Accessory #3 2 10GB Asustor NAS 7000 series
- Join Date
- Jan 2013
- Reputation
- 13
- Posts
- 309
There are a number of internal usb hubs of differing configurations available on Amazon, Newegg, and Ebay.
I believe it incumbent that you peruse the offerings and make you own choice of which one best fits your requirements.
You'll be proud of your selection and not blaming any members here if you don't like the outcome.
05-16-2021 04:04 AM #3
- Join Date
- Mar 2015
- Reputation
- 19
- Posts
- 106
05-16-2021 07:10 AM #4
- Join Date
- Jan 2013
- Reputation
- 13
- Posts
- 309
I personally prefer one powered from a PSU power cable and not from the USB port.
05-16-2021 01:31 PM #5
- Join Date
- Mar 2015
- Reputation
- 19
- Posts
- 106
Hello G75rog,
i think so to , becuause is for the RGB fans and so on should be better with extra power , i ill look for one with SATA power connector ... i already looked yesterday and there are a lot, well i need to see what should be a good one , i like the look from the NZXT with manetic base , but i dont know what these people did to this HUB so the power cable was melting? was it bad quality or maybe they didnt use it correctly ?? Thanks for the Answer again , i keep reading here , maybe someone has the NZXT internal Hub and can tell me is it ture that isnt a good idea or maybe its good for the corsair lihging core, i belive this lightning core is not drawing to much power ...
With friendly greetings
Nonny
EDIT: Ok I made now a proud decision and i belive it fits the needs im wanted i will go for corsair commander pro it has allready 2 USB included so when this is not working i know who to blame, but i think its not the cheapest solution but maybe the savest , some reviews on more compfotable solutions i dont like , so is think best is stay with the brand what its made for so case is closed ! ;-)
NonnyLast edited by Nonny; 05-17-2021 at 03:23 PM. Reason: a proud decision ;-)
