Armoury Crate ROG STRIX RTX3060 update issue with Corsair iCUE V4 .11.274 issue
ahfoo
Just buikd a new system with ROG Strix RTX 3060. After applying the latest updates Version 20210128 to the armoury crate, I am now stuck only can control the RTX3060 with armoury crate and not the iCUE version 4.11.274. Anyone encounter this and any solution ? Thank you.
DjRavix
Have you installed the Aura Plugin that is on the Corsair website ?
and also this might be useful
https://help.corsair.com/hc/en-us/articles/360035656371-Enable-Aura-Sync-control-for-your-Corsair-RG...
ASUS Maximus 13 Extreme
Intel i9 11900K
Corsair Dominater Platinum RGB
Phanteks Enthoo Primo
Samsung 980 Pro 1TB
2 X Samsung 980 Pro 2TB
Corsair AX1200I
EK-Velocity D-RGB - Nickel + Plexi
EK-XTOP Revo Dual D5 PWM Serial - (incl. 2x pump)
XSPC RX480 + XSPC RS280
4 X Corsair SP120 PWM OEM Fans
2 X Noctua NF-A14 industrialPPC-2000 IP67 PWM
2 X Noctua NF-A14 PWM chromax.black.swap
2 X Noctua NF-S12A PWM chromax.black.swap
1 X Noctua NF-A15 HS-PWM chromax.black.swap
